Old 01-05-07, 02:30 AM   #1
phil24_7
Default Tread Direction
The tread pattern on my Metzler Z6's appear to go in opposite directions. Is this correct??
The rear appears to rotate so that water would be pushed outwards away from the tyre but the front appears to run in the opposite direction so that water would be pushed into the centre of the tyre!
Anyone got Z6's that are fitted the same/differently?
Regards
Old 01-05-07, 05:54 AM   #2
rictus01
rictus01's Avatar
Default Re: Tread Direction
Can't honestly remember, but the manufacturer helps you out with a big arrow for rotational direction, I've had several sets of these and they work well as a pair in the wet (or mixed with the strada's).
(Slightly)
Interesting fact, haven't seen it in a while mind, but you used to get tyres that fitted one way round for the front, and the same tyre could be fitted the other way round to the rear, now that was confusing
Cheers Mark.
Old 01-05-07, 07:28 AM   #3
the white rabbit
I think there was a thread on this a little while ago with moulds being incorrectly labelled...or was that Continental?
Old 01-05-07, 06:49 PM   #4
phil24_7
Yeah I read that but I think it was the conti's.
Was just looking for some clarification on the Z6's.
Anybody goe a set they can check??
Old 01-05-07, 08:41 PM   #5
Baph
Looking from the back of the bike (and back of each wheel):
The rear has a strip down the middle with no grooves in it. The main grooves run down & out in a curve. There's a smaller groove that runs up as well.
The front, has a zigzag line running down the middle. Theres smaller grooves that run upwards & out as well.
Old 01-05-07, 11:15 PM   #6
phil24_7
Cheers.
I'll see if that makes sense in the morning when i'm looking at the bike!
Old 02-05-07, 07:49 AM   #7
Jdubya
Perhaps a few people could post pictures for comparison?
Old 02-05-07, 08:20 AM   #8
Alpinestarhero
Regards
Yea, i thought this too when my tyres where being fitted, but on the sidewall there is an arrow indicating the direction of rotation, which I have done correctly (i.e. the tyres rotate the correct way).
Matt
Old 02-05-07, 08:36 AM   #9
Mogs
Z6's have been out long enough for a mistake with the rotational direction to have been corrected. Avons have a similar pattern that looks wrong at the front.
Old 02-05-07, 09:41 AM   #10
Baph
Matt
What about when you're pushing the bike backwards? Do the arrows point in the right direction then?
M25 direction advice please embee Idle Banter 11 16-06-08 09:34 AM
Spotted - some pointy SVs out in the moors direction Tim in Belgium Pennine Massive 0 24-05-08 07:47 PM
Tread Direction in_your way_racing Track Days 6 30-01-08 12:15 PM
Sense of direction Dicky Ticker Idle Banter 22 06-01-08 12:03 PM
Pirelli Diablo Stradas & direction of tyre muffles SV Talk, Tuning & Tweaking 25 21-09-06 10:21 AM
