Old 06-05-07, 11:34 AM   #1
big_dawg
Default Modifying...(streetfighering SV)
Hiya, i crashed my k2 faired sv and i'm streetfightering it now but i can't find a speedo, i was wondering if the speedo on the unfaired will directly connect, also if not then what about the speedo on the pointy sv???? Any other suggestions welcome as i can't find a speedo nowhere, also anyone know the diameter of the forks???? i think it's 41mm but am not sure.
Cheers!!!
Old 07-05-07, 09:51 AM   #2
skumlerud
Default Re: Modifying...(streetfighering SV)
A speedo/tach from a naked will work. It does have different connectors than a S though, so you need to replace those.
I'd recommend these though: http://trailtech.net/vapor.html
Add one of these http://www.trailtech.net/022-PDA.html and you have everything you need. I have this on my SV (curvy SVS converted to naked) and it works really well.
It's 41mm.
Old 07-05-07, 06:38 PM   #3
Loads of people have reported problems with the tach on the Vapor, did yours work alright?
Old 07-05-07, 07:21 PM   #4
skumlerud
No problems at all. I connected the tach to the coil just like the original tach (in fact, I used the original wire as well and spliced it to the Vapor tach wire inside the headlight shell) and it worked straight away. It's worth mentioning that the tach wire I got from Trailtech had an inline resistor, that might be why I didn't have any problems.
Old 07-05-07, 07:49 PM   #5
Ah, cool.
Old 08-05-07, 11:25 AM   #6
socommk23
acewell! they are good clocks had one on my sv
Old 08-05-07, 11:45 AM   #7
riktherider
i recomend the vapour as well. looks neat if you get the aluminium surround as well. had no problems with the tacho. wrapped the wire supplied around the front ht lead and hey presto works first time!!!!
i im not using any of the idiot lights though, just got a seperate oil pressure guage and it all works fine and dandy.
Old 08-05-07, 12:04 PM   #8
big_dawg
Thanx a lot everyone!!!! Will keep u updated...
modifying footpegs erik SV Talk, Tuning & Tweaking 14 08-02-09 06:44 PM
Modifying / replacement seat - help my boney ar*e! Bayside GTR SV Talk, Tuning & Tweaking 44 28-04-08 11:40 AM
Baffle Modifying GDBD59 SV Talk, Tuning & Tweaking 6 21-04-06 01:59 PM
Exhaust tuning/modifying ??'s Svsniper SV Talk, Tuning & Tweaking 9 04-07-05 12:17 AM
standard undertray modifying cassius SV Talk, Tuning & Tweaking 17 19-02-05 11:59 PM
