Old 10-05-07, 04:13 PM   #1
DanF
Default Front suspension tips (Emulators again) :p
Hi,
I put some progressive springs and heavier oil in my front suspension a couple of weeks ago. The oil is "heavy" 10w.
What I'm finding is that the low speed has been improved, less brake dive, harder to bottom out suspension under braking/hitting bumps etc but the high speed has become more harsh over ridges etc.
I'm guessing the only real thing to do now would be buy some emulators so I can control the low/high speed in a different ratio.
Also I might try to increase the air gap to lessen the progressive ramp of the spring + air pocket combining. What do you think.
Old 10-05-07, 06:01 PM   #2
steveg
steveg's Avatar
Default Re: Front suspension tips (Emulators again) :p
I'm interested in this thread as have just ordered some Hagon springs .
What springs did you fit ?
The chap at Hagon was really helpfull , said that the pointy kit comes with 10W oil , where as the curvys use 15 W ?
Will get em fitted next week , thought they were a bargin at 62 quid with oil & next day delivery .
A quick question how much do you weigh , I was under the understanding that if you weighed 10 - 11 stone you don't need stronger springs ?
I weigh 15 stone so need the man size springs
Cheers Steve
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 10-05-07, 06:04 PM   #3
Lissa
Just Ballast
Lissa's Avatar
The man from Hagon talks b*ll*cks!
Curvy's use 10w too as standard!
Old 10-05-07, 06:28 PM   #4
DanF
I weigh in at about 11 1/2 stone in my boxers. The springs are progressives that are about equivalent to .80's, probably a bit softer to begin with then get a little harder. I'm looking to do more trackdays + spirited weekend driving so a more firm frontend is a good compromise.
There's actually quite a range of oil viscosity in the 10W division, the cST is a bit more accurate. The oil I used was Castrol synthetic fork oil @ 42cST which is very near the point that 15W oils start. Probably would have been better putting something a little thinner in.
http://www.peterverdonedesigns.com/lowspeed.htm
Old 11-05-07, 08:58 AM   #5
johnnyrod
johnnyrod's Avatar
What sag are you using? I found with these springs that you wind in the adjusters by one and a half turns and it goes from fine for me to fine for two-up, hell of a difference. 15W oil would be better than 10W so doesn't sound like that's the problem. (PS I have the same springs on my curvy plus emulators)
suspension tips somnus SV Talk, Tuning & Tweaking 4 12-08-07 02:47 PM
Tips for unloading rear suspension without ABBA stand Luckypants SV Talk, Tuning & Tweaking 8 06-03-07 11:46 AM
New springs and emulators.Couple of tips. petevtwin650 SV Talk, Tuning & Tweaking 0 23-07-06 01:04 PM
Front suspension Fuzz SV Talk, Tuning & Tweaking 14 03-05-06 11:56 AM
Suspension tips for a fat git Mikey G SV Talk, Tuning & Tweaking 5 03-07-05 06:41 AM
