Old 11-05-07, 09:14 AM   #1
danf1234
Default Rear Shock removal
Is there a tried and tested method for removing the rear shock to get a new ohlins replacment in there.
Do I need to remove the tank or can the top bolts be done from the side.
Are there any potential problems?
PS I have used the search function and I can't find an anwser.
Old 11-05-07, 12:28 PM   #2
Caddy2000
Default Re: Rear Shock removal
I used:
1 ABBA stand
2+ soft dusters
1 adjustable strap (for the tying down of cargo etc), but you can use string etc.
1 heavy item to put on the front wheel to keep it down on the ground.
Also lots of tools, breaker bars, and extension bars.
If you have a rear hugger remove it!
Get the bike up on the stand.
Pass the strap through the top of the rear wheel and then over the seat.
USE THE SOFT CLOTHS TO PREVENT ANY SCRATCHING THAT MAY OCCUR.
Tension the strap so the rear wheel lifts slightly.
Undo the bolts on the bottom of the shock.
Let the rear wheel down slowly
Remove the top bolts from the shock
At this point decide whether you want to clean and lube the dogbones or anything else that's there!
Put the new shock in at the top.
Lift the rear wheel up to the right height so the holes on the dog bones and the hole on the bottom of the shock line up.
Tighten the strap os that the holes are all in line.
put the bottom bolts in.
release the strap.
Torque up to the right setting.
If you've got a mate handy use him instead of the strap!!!
Old 11-05-07, 03:41 PM   #3
danf1234
So you managed to do it without removing the rear wheel at all???
Also what are the torque settings for the shock bolts top and bottom, and the dog bones?
Cheers,
Dan
Old 11-05-07, 06:55 PM   #4
Tim in Belgium
Sure they'll be in a Haynes manual, worth getting if you're thinking about working on this type of thing with your bike.
Old 12-05-07, 12:16 PM   #5
danf1234
Advice taken and manual bought. Now lets get modding
RH rear panel removal branny SV Talk, Tuning & Tweaking 9 15-05-09 02:08 PM
rear grab rail removal joemcfarnham SV Talk, Tuning & Tweaking 14 10-07-08 11:16 AM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
Rear Wheel Bearing Removal TSM SV Talk, Tuning & Tweaking 10 20-03-06 10:54 AM
Rear Brake Pedal Removal??? MarkyBoy SV Talk, Tuning & Tweaking 6 12-08-05 02:15 PM
