Old 16-05-07, 06:15 PM   #1
the white rabbit
Default Car cambelts
Time or mileage?
The change is due at 63,000 and the car has got 43,000 on it, but based on 12 months service intervals this would be 7 years and this car is older than that.
So if its miles its good for another 20, if not needs changing.
Advice? Ta
Old 16-05-07, 06:19 PM   #2
Default Re: Car cambelts
id go on miles myself, i just sold my focus with 60k on the clock it was due a timing belt, the car was 6 years old.
Old 16-05-07, 06:47 PM   #3
Razor
Pop the cover off and check it's condition if you can. I still remember the sound my 16 valve Honda Civic made when the belt snapped and the piston smacked the valves
Old 16-05-07, 06:49 PM   #4
DoubleD
I have always gone on mileage, but then I'm due my second cam belt change and the car is only 3½ years old!
not much help am I
Old 16-05-07, 06:52 PM   #5
DoubleD
I have had to replace 8 valves when mine went, 1 week after buying my first car.
Weird how harden steal valves bend and soft aluminum pistons are fine!
Old 16-05-07, 07:18 PM   #6
neio79
miles .
Old 16-05-07, 07:27 PM   #7
Stig
Well,
Considering that the cam belt is made of rubber. Rubber deteriorates over time. Also bearing in mind that I have also had a cam belt snap on a 16 valve engine to only have one valve that could be deemed anywhere near straight after.
I would put my money in my pocket and get it replaced. Cost of a new engine over the cost of a cam-belt and piece of mind.
Old 16-05-07, 07:36 PM   #8
fizzwheel
fizzwheel's Avatar
Thats what I'd do to. If your not sure get it changed.
Old 16-05-07, 08:58 PM   #9
Gazza77
Gazza77's Avatar
Time definitely, it could get expensive if it goes. Same for all consumables in the service schedule. Having said that, if it is a non-interference engine (some Mazda ones are) if it does go, all it will mean is you coasting to a stop until a new one is fitted.
Formerly Blue K5 with added bits
Then Triumph Sprint ST with scottoiler and R&Gs & TOR exhaust
Now Benelli Tornado
Gazza77 is offline   Reply With Quote
Old 16-05-07, 09:00 PM   #10
muffles
I'd go for time or mileage whichever is first, as mentioned it's rubber and that deteriorates over time. If you are able to check, though, that's a good thing to do.
