Old 16-05-07, 09:12 PM   #1
Tim in Belgium
Default Hard Core Fork photos
OK, so more the mild ingredients for a gentle fork upgrade:
Ohlins springs, oil and suzuki preload adjusters for my old curvy.
Some rear end "shocking" photos should follow by the weekend!
Old 16-05-07, 09:47 PM   #2
Razor
Default Re: Hard Core Fork photos
No emulators?
Old 17-05-07, 06:59 AM   #3
Tim in Belgium
Correct, no emulators
Old 17-05-07, 09:57 AM   #4
Razor
That's what I thought.
Old 17-05-07, 10:35 AM   #5
petevtwin650
Is that enough oil for both fork legs?
Hope you got the washers too for the preload adjusters?
Old 17-05-07, 10:41 AM   #6
chazzyb
TBH, I'd have thought emulators would have given better results. Fancy springs and oil aren't going to cure the basic high-speed compression damping problem SV forks have.
Good luck, I'm going to buy me some emulators.
Old 17-05-07, 11:17 AM   #7
Tim in Belgium
Got the washers as well, just you can't see through the plastic bags.
Not bothering with emulators at the moment, may consider them in the future if I'm not happy, but prefer to spend my cash on petrol, trips and track days than upgrading the bike. Just wanted a slightly firmer front end on track.
Old 17-05-07, 11:22 AM   #8
Blue_SV650S
progressive or linier springs?
Old 17-05-07, 11:33 AM   #9
Tim in Belgium
Linear.
Old 17-05-07, 11:33 AM   #10
timwilky
timwilky's Avatar
You will need to cut about 13mm off the existing spacer tubes to adjust for the extra depth of the adjusters
Not Grumpy, opinionated.
How hard can it be ? Stig Idle Banter 2 18-11-07 05:17 PM
Has anyone ever heard of or seen a fork slider save a fork-track or road (Not SV!) monkey Bikes - Talk & Issues 8 28-10-07 11:59 PM
Core 2 Duo 2.13Ghz vs Pentium D Dual Core 3.4Ghz Nekkid Idle Banter 9 22-08-06 10:17 AM
K4 fork spares, damper tubes,preload adjusters,fork lowers ianofbhills For Sale - SV's and SV related items 11 13-03-06 06:58 PM
Nitty gritty hard core Stig Soho Massive 15 08-10-04 01:12 PM
