Hi
Just got one of these nifty pieces of kit, however, just tried to use it, and it fouls the brake pedal ![]() Any one had this problem and solved it? Or am i going to be the first? Btw K4 Pointy full fairing |
Trinity
Same.
I used to get a plank of laminate flooring (i.e. any thin plank) to guide the brake pedal inside the stand. Now I've got an ever so slightly bent heel plate I don't think it fouls anymore. |
Put a socket in the right hand swing arm recess*, then fit the NWS as normal, this spaces the lift out on the right and stops it hitting the pedal
*I've got an old 14mm socket that fits well, mine is an SV1000, your bike/sockets may be different sizes but I'm sure you'll work something out.
The Sick Man
I dont have a problem on my SV, but thats prolly because i have rearsets.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
No, it's cos you've got a curvy. The hole in the swingarm pivot of the pointies is a much larger diameter, the tapered pin of the NWS thus goes much deeper into the hole and therefore the stand leg is close enough to the bike to foul the brake lever.
Putting a socket into the hole reduces it's diameter making the pin enter less and the stand leg is held further from the bike.
I don't have this problem but then I have a Abba stand.
#7 | |
The Sick Man
#8 | |
SV1000S K4, Hugger, Scottoiler. Lowers |
#9 |
i used a 12mm socket, fitted perfectly. thanks for the advice, you guys
![]() i considered the abba, but it was the nws came up on ebay locally first ![]() |
#10 |
Trinity
Oops you paid a lot of money for it - but they are hard to come by on ebay & should last forever apparently
Paddock stand/abba stand or? | Ruthja2801 | Bikes - Talk & Issues | 18 | 26-02-09 12:20 PM |
center stand / abba stand? | New Leaf | Bikes - Talk & Issues | 3 | 29-01-08 01:58 PM |
Using a front paddock stand... help!(fitment problem) | rich_r | SV Talk, Tuning & Tweaking | 4 | 10-03-07 10:25 PM |
Storage: Side stand or rear paddock stand? | Maudster | SV Talk, Tuning & Tweaking | 19 | 20-01-07 04:45 PM |
Abba Stand or MWS stand | New Leaf | Stuff Wanted | 7 | 30-12-06 05:44 PM |
