Old 23-05-07, 07:06 PM   #1
zunkus
Default Steering reluctant to turn
Coming from work I've noticed the steering reluctant to turn from the straight centre position. Makes the bike somewhat notchy in long bends. It sort of has a slight click into centre position.
I've read somewhere that this is the sign of head bearing trouble. Malta is pothole country so I'm not being inspector Morse to guess how this fault emerged.
So should I order the whole lot, top, bottom bearings and races. Are there improved items over stock OEM, roller bearings maybe?
Out of curiosity, if you've had this experience what normally gets nackered the bottom or upper bearing?
Old 23-05-07, 07:41 PM   #2
chazzyb
Default Re: Steering reluctant to turn
Do the lot. Taper rollers are *probably* cheaper than OEM cups, cones and balls.
Old 23-05-07, 07:45 PM   #3
admin
John T
admin's Avatar
Hi Steven. Sounds like head bearings to me. Had my fair share of these over the years. The SV has balls as apposed to roller bearings which surprised me as my old 1989 GSX had taper rollers as standard. Does it feel like the back tyre is a bit flat when you corner?
Get the front of the bike into the air and take off the front wheel and then turn the steering. Without the weight of the wheel to dampen things the notchiness will be really apparent.
I'd replace the whole lot with tapers, although I'm not sure of their availability for the SV.
Don't over tighten the new head bearings, give them a few hundred miles to bed in and then check for play.
John
Old 23-05-07, 07:53 PM   #4
chazzyb
Taper rollers are standard sizes from memory, I just can't remember what. Once you know what they are, a bearing merchant will be able to supply. A bike-type supplier will know what they are and sell you a set for *more* money. I seem to recall that the lower race had a seal on it (1RS designation?). The OEM lower race dust shield *will* get destroyed during the operation.
Old 23-05-07, 08:20 PM   #5
zunkus
Yes John, did the front elevated thing and also inflated the front tyre before that to see if it had anything to do with that as well but sorry for me to say that the bearings have to go. The thing is that I don't know of anyone who has replaced to tapered so don't know what I'd be getting into. You know me John if I could improve things I'd do it, I just want to be sure its the right thing to do.
Old 23-05-07, 08:40 PM   #6
sinbad
Make sure the steering head bearing nut isn't over tight first.
Old 23-05-07, 09:12 PM   #7
zunkus
I have found these taper bearings:
http://www.gear4bikes.com/cgi-bin/sh...%23a7670#a7670
but they don't offer any information about their seating cups. Since the bearings are different (being taper bearings) won't you need new cups for them to seat into?
If you're reading this and have done the mod please give me details of the tapered bearings, part number and make? I'd like to buy the bearings first so that I'd already have them before I dismantle so as to maximise riding time as much as possible.
Old 23-05-07, 11:34 PM   #8
Lozzo
Ow Zunkus, kifinti?
You can buy taper roller steering head bearings as a complete set for the bike, this includes the inner and outer parts of both the top and bottom bearings. It's always adviseable to replace the lot when you do them.
Try here: http://www.mandp.co.uk/productInfo.aspx?catRef=508447
Wave to my family on Rue D'Argens, Msida when you next ride up there.
Chow jbien
Old 24-05-07, 09:20 AM   #9
zunkus
Thanks Lozzo. I see that the kit includes the cups to be inserted into the frame tube. Nice. So have you done the conversion to yur bike? Thanks for the Maltese talk by the way. So are you Maltese? Maybe we'll get to meet on the road. I'll be coming next month to tour the place for 12 days. I'll be opening a topic to say where I'll be when I start the tour.
Old 24-05-07, 05:21 PM   #10
Lozzo
I'm 3/4 Maltese, but brought up over here and you've just experienced my total knowledge of the Maltese language, so don't go talking it to me.
I haven't fitted taper roller bearings to my SV yet, but I no doubt will eventually. I have fitted them to many many bikes in the past, for myself and friends. It's not the easiest job, but with time and patience it can go smoothly. You'll need some long pin punches and a method of sitting your bike upright and secure when the wheel and forks are out. I have this stand,similar ones are available from a company called Abba:
Attachment 74
It's strong enough for my old GSXR1000 to sit on with no wheels in for three weeks.
Good luck
Reluctant sale of my R6 Messie Idle Banter 19 07-10-08 07:06 AM
Key wouldn't turn hedgehog SV Talk, Tuning & Tweaking 12 01-09-08 03:28 PM
Reluctant freezer tigersaw Idle Banter 12 07-02-08 08:41 AM
Steering lock for Steering damper Sideshow#36 SV Talk, Tuning & Tweaking 8 30-08-07 11:18 PM
Reluctant starting chutz SV Talk, Tuning & Tweaking 13 16-11-04 06:28 PM
