Old 24-05-07, 08:25 AM   #1
Grinch
Default Fork Seals.
Helga has rather nicely decided to blow a fork seal (prob to help celibate her 50th), so looks like I'm going to have to get it done this weekend.
Now having not done this before I would love any tips or tricks you might have to do this job. I do have my manual that I will be reading through, but I know may of you will have some little insights that will make the job easier.
Also is it bad of me to ride about with this blown seal, its leaking a bit, but not chucking oil every where.
Old 24-05-07, 08:40 AM   #2
fizzwheel
fizzwheel's Avatar
Default Re: Fork Seals.
Undo the bolt in the bottom of the fork, before you undo the fork caps and take the springs out. If you try and do it after the whole lot just spins round and you'll end up putting it back together again to undo the bolt.
Oh and theres a little plastic bush that goes in there somewhere to. When you take it all apart the bush will be wedged kind of in the spring, I had trouble working out to how to get it apart, in the end I used small thin metal bar to push the bush out of where it was stuck.
Sorry this is a bit vague but it was ages ago and I can't remember, if you've got access to a haynes manual the diagrams in there a pretty useful.
Old 24-05-07, 09:02 AM   #3
weazelz
blown a seal? no wonder she's celibate. maybe it's just snow in her moustache
Old 24-05-07, 09:05 AM   #4
DoubleD
LMAO
Old 24-05-07, 09:10 AM   #5
Grinch
Yer alright... I typed it in a hurry as I'm at work.
Old 24-05-07, 09:29 AM   #6
Viney
When squid done mine, he used all manner of broom handles and drianpipe. Done the job though
Old 24-05-07, 09:56 AM   #7
Grinch
That sounds more like he was trying to put guttering up...
Old 24-05-07, 11:45 AM   #8
John Burt
Top tip - use oe seals in my experience cheap pattern seals just don't last
Fork oil seals, which way up? Ceri JC SV Talk, Tuning & Tweaking 5 04-03-09 07:33 PM
Fork Seals chris8886 SV Talk, Tuning & Tweaking 2 04-02-08 09:04 PM
Fork seals have gone JakeRS SV Talk, Tuning & Tweaking 3 23-07-06 12:29 PM
fork seals ruff_ryder SV Talk, Tuning & Tweaking 11 29-06-05 05:43 PM
Fork Seals and Oil R11ysf SV Talk, Tuning & Tweaking 1 11-03-05 10:46 AM
