Old 26-05-07, 07:04 PM   #1
rigor
Default How do I work out theoretical rear wheel revolutions?
OK, messing about with stuff, and was just trying to work out how you calculate the theoretical wheel speeds for a known RPM and gear. I've got the gear ratios, and Primary and Final reduction ratio, but my brains tired, and I can't quite work out the figures.
Anyone got any ideas?
Old 26-05-07, 07:39 PM   #2
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Default Re: How do I work out theoretical rear wheel revolutions?
i would have though rear wheel rpms would be
RW RPM = (Engine RPM) * (1 / Gear Ratio) * (1/Final drive ratio)
Gear ratios:
1st = 2.461 (32/13)
2nd = 1 .777 (32/1
3rd = 1 .380 (29/21)
4th = 1 .125 (27/24)
5th = 0.961 (25/26)
6th = 0.851 (23/27)
Final drive ratios:
SV650 = 3.000 (45/15)
SV650S = 2.933 (44/15)
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 26-05-07, 07:41 PM   #3
rigor
Ta
Old 26-05-07, 07:50 PM   #4
the_lone_wolf
Captain Awesome
Originally Posted by rigor View Post
Ta
well i know that if i'm in second gear 5k rpm is as near as dammit 30mph
so, a bit of math
rear tyre is 17 inches in diameter, which = 0.432m, therefore the wheel's circumference is (2 * pi * radius) = (2 * 3.14 * (0.432/2)) = 1.36m
30mph = 48000 meters/hour = 13.3m/s
number of wheel revolutions per second = 13.3/1.36 = 9.78
therefore rear wheel rpm = 9.78 * 60 = 587rpm
______________________________________
now calculating the other way:
5000rpm * (18/32) * (15/44) = 958rpm
sounds reasonable to me
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 26-05-07, 08:47 PM   #5
stuartyboy
Old 26-05-07, 08:51 PM   #6
the_lone_wolf
Captain Awesome
Originally Posted by stuartyboy View Post
rpm = (mph x gear ratio x 336) / diameter
units?
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 26-05-07, 09:26 PM   #7
stuartyboy
Old 26-05-07, 09:30 PM   #8
the_lone_wolf
Captain Awesome
Pounds and ounces lol
i meant the diameter...
using inches in this formula:
gives you just over 1000rpm for 30mph in second gear - not right unless they accidentally put the cogs on my bike back to front...
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 26-05-07, 10:41 PM   #9
Ed
Could I ask - why do you need this information? Will it materially improve your life? TBH I've managed many years without even thinking of the calculation let alone trying it and I can't say I'm bereft
Old 26-05-07, 11:09 PM   #10
$tevo
Isn't 17 inches the wheel diameter rather than the tyre diameter? And there's a primary gear reduction to factor in as well?
Anyway, my head's hurting and I can't find a late night kebab house in Willenhall that delivers and I've got to go to bed hungry so I'm in a bad mood
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
Theoretical Questions You Need To Know The Answer Too..... Welsh_Wizard Idle Banter 20 04-12-07 02:19 AM
2 wheel junkies body work? ? would you? John 675 SV Talk, Tuning & Tweaking 29 04-07-07 08:31 AM
Theoretical acceleration question Warthog Bikes - Talk & Issues 29 10-05-07 06:58 PM
Abba wheel spin.does it work? ged Ancillaries 8 03-03-07 10:32 PM
