Old 28-05-07, 06:08 AM   #1
lokidragon
Default startup problem
hey all,
new to riding and had a bit of a problem, dropped the bike, and now it won't start, the battery is working good, and everything else works fine, but will only start when I push start.
When i goto fire it up, no clicking, no sound no nothing. help
Old 28-05-07, 06:14 AM   #2
hovis
Default Re: startup problem
Originally Posted by lokidragon View Post
hey all,
what bike is it?
Old 28-05-07, 06:17 AM   #3
lokidragon
99 sv650
Old 28-05-07, 06:43 AM   #4
hovis
could be the clutch switch or sidestand switch?
have you checked the red cut out switch it not off?
Old 28-05-07, 06:47 AM   #5
lokidragon
the kill swtich? it's in the on position, everything is operating normally, and i know i'm doing the correct start up sequence
Old 28-05-07, 06:50 AM   #6
hovis
check the conector has not come off of the clutch switch first
Old 28-05-07, 06:59 AM   #7
hovis
have you checked the fuses?
Old 28-05-07, 07:11 AM   #8
lokidragon
yep, the clutch cable is still on there and functioning, I took it out for a spin after a push start and it worked fine, the fuses's arn't blown, and the battery is good, like i said it functions normally, just won't fire when i push the ignition switch. but will start and run fine with a push start
Old 28-05-07, 07:25 AM   #9
hovis
not the clutch cable, its a little connector that clips underneth the lever, make sure its on & clean.
failing that im not sure, could me a dodgy ignition switch ?
best wait for sombody with a bit more knowlage (have you done a search? )
Old 17-06-07, 06:59 PM   #10
hbaden00
Did you figure out the problem. Also you might want to clean out the air filter. When you dropped the bike oil comes up tot eh air box. If you start it there will be smoke from oil and will take some time to bun it off. The best thing would be to use something like simple green which is an all around cleaner to clean out the air box so no oil gets back into the the carbs.
in terms of the starting issue make sure nothing got bend or out f place. The one thing to check that many people miss is the kick stand relay. if that is bent or dammaged the bike will not start due to it being a cut off switch when the stand is down unless the bike is in neutral. Let me know how it fairs.
Howard
Startup Error - What does it mean? Doofer SV Talk, Tuning & Tweaking 11 26-03-09 09:59 AM
groggy startup and lose of power with backfiring hbaden00 SV Talk, Tuning & Tweaking 2 19-06-07 08:09 PM
Clunky Startup.. Daimo SV Talk, Tuning & Tweaking 8 29-01-07 03:06 PM
Clonking on startup Warthog Bikes - Talk & Issues 16 15-06-06 09:48 AM
