Old 29-05-07, 03:03 PM   #1
plowsie
Default Gear lever as rear brake lever?
Is it possible to do this? I have so many gear levers spare at home it would be a shame to waste. And the fact that they are 50ish quid for new rear brake lever
Old 29-05-07, 03:07 PM   #2
haggis
Default Re: Gear lever as rear brake lever?
If you have a City&Guilds in Bodge-ism then I suppose it could be a yes, otherwise it's a no.
Old 29-05-07, 05:23 PM   #3
rictus01
rictus01's Avatar
Well you'd have to obviously use it upside down, and the gear pedal lacks the tail eyelet or metal to drill one, you could make a plate to attach to the pedal extending backwards and affix the rear master cylinder link to that, how are your machining skills ?
So yes it could be done, but it's the effort/time/skill involved that may make you think twice about doing it.
Cheers Mark.
WTD - rear brake lever, front brake lever, r & G crash bung, nik_nunez Stuff Wanted 0 17-10-08 08:27 PM
How to straighten a bent gear lever? (heat it up first? or what?), ---possible fix or recipe for snapped of gear lever :-) martin_SV SV Talk, Tuning & Tweaking 10 30-07-08 08:40 PM
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. Bayside GTR Stuff Wanted 0 29-10-07 11:24 PM
2 left indicators + clutch lever + gear lever for pointy k6 enduroman Stuff Wanted 3 06-09-07 09:26 PM
Re-placement gear and rear brake lever Osiris SV Talk, Tuning & Tweaking 8 23-05-05 02:28 PM
