Will be there on the Sunday, but dont if I can make it on the Saturday will have to wait and see
Who is going then?
Let's have the whole ecosse mob there! (and maybe some of the 'foreigners that make the journey too) i can usually get a car pass for it so if so i will be designated driver for the bar b q stuff and i will probably pitch a wee tent - lets see how the weather goes. Let's get this one sorted in advance yeah. Get a sv ecosse base so people can leave their gear safe and take it in turns to do the wander.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
We'll be there.
And I'll make sure I check out here before hand to find out where everyone is gonna be ![]() |
Whilst it's closer than normally would be, being the last day of AE07 and 185 mile from the camp site, I'll not be attending, perhaps another year.
Cheers Mark.
I'm heading south after the AE07 subject to weather, Its unlikley I'll make it there anyway.
I could go but I'd need to pass a divorce court on the way, off to John O'Groats with the Essex Lounge starting on the Monday.
Next year or perish in the attempt! |
We'll be there at the same place as last time. Normally there is a coach set up where you can leave all your leathers and lids etc for a nominal fee. though it fills up quick on Sunday. We go there at 8ish last year probably just as well it was packed.
Is knockhill near Hoddom because my google earth picture of it isn't all too clear
#10 |
Just found out that Knockhill radio is on most of the time and the signal reaches south queensferry!
1602am - if you within that sorta radius when a meet is on check it out, it's highly recommended to visit your local instore and grab a cheap headphone radio to use if your ever going to knockhill for one of their big days as the tannoys are rubbish!
A bad day - Sunday 27th July | Luckypants | The Border Patrol | 9 | 29-07-08 04:21 PM |
Sunday 1st July | Dicky Ticker | SV Ecosse | 7 | 21-06-07 09:05 PM |
Ace Cafe Sunday 1st July | Moffatt666 | Rideouts & Meetings | 11 | 01-04-07 09:14 PM |
July Sunday 2nd Suzuki SV and Bandit Sunday ACE CAFE | jonhunt | Rideouts & Meetings | 20 | 28-03-07 08:00 PM |
Sunday 2nd July | Balky001 | The Essex Lounge | 2 | 30-06-06 04:45 PM |
