Old 10-06-07, 07:24 PM   #1
neio79
Default ZX10R shock
Simple questrion will a 04/05 ZX10-R shock fir onto my K3 pointy with no adjustments being needed to the bike?
If so is there anyone (competent) out there willing to help me fit it for the cost of a crate of beer and an afternoon of my company??
Old 10-06-07, 08:37 PM   #2
weazelz
Default Re: ZX10R shock
I have one on my curvy & it works well. which means it's probably too long & too hard (fnar fnar) for a pointy
Old 10-06-07, 09:34 PM   #3
Blue_SV650S
Yep, I think you want a GSXR one for the pointy
<Swiped>
YEAR MOTORCYCLE LENGTH SPRING
00-03 GSXR750 325mm 400#
01-03 GSXR600 325.5mm 325#
01-02 GSXR1000 329.5mm 430#
03-04 SV650 330mm 430# <<<==== stock 2nd gen...05 should be the same
99-03 GSXR1300(Busa) 330mm 700#
04 GSXR750 332.5mm 408#
04 GSXR600 332.5mm 425#
03-04 GSXR1000 332.5mm 480#
99-02 SV650 337mm 510# <<<====stock 1st gen
04 ZX10R 338mm 540#
03-04 ZX6R(636) 340mm 540# *corrected by e lo...thanks!
96-99 GSXR750 345mm 375#
97-00 GSXR600 375mm 375#
05 GSX-R 1000 332.5mm 450# <<<===added by me...spring rate from racetech.com, length from ohlins.com
<end>
Old 10-06-07, 09:48 PM   #4
neio79
so the ZX10 one will fit then? i mean in tearms of bolt sizes etc and the mounting positions.?
how does the spring lengt fit, as surley that can be changed under pre load?
I ask as there is a decent ZX-10R shock goig on ebay. but i am opent to sugestions of shocks that people know 100% fit straight in with no hassle. i dont have to worry about the tool holding box that hangs down as its o K3 so Suzuki placed it in a proper place.
Old 10-06-07, 10:02 PM   #5
weazelz
shock length, not spring length
Old 10-06-07, 10:08 PM   #6
neio79
oh got you. so the 10R is 8mm to long? so i assume it wont fit?
what shocks have people put in their pointys then? (from other bikes)
Old 10-06-07, 10:20 PM   #7
weazelz
it probably will, but it'll jack you back end up by 1-2", which may (or probably won't) be what you want
see blue_sv650s' post above. people generally put gixxer shocks in pointies
Old 10-06-07, 10:27 PM   #8
neio79
will this do?
http://cgi.ebay.co.uk/Suzuki-GSXR-10...QQcmdZViewItem
Old 10-06-07, 10:41 PM   #9
weazelz
length & stiffness match. do you want a 5 year old shock though? do you believe that an '02 gsxr1000 had done 4,000 miles?
Old 11-06-07, 03:28 PM   #10
neio79
if the milage is genuine it would bea good replacement no??
04/05 ZX10R shock andyb Stuff Wanted 1 17-05-08 07:46 PM
'06 zx10r rear shock weazelz For Sale - SV's and SV related items 0 04-12-06 09:26 PM
zx10r shock weazelz SV Talk, Tuning & Tweaking 10 26-08-06 08:25 AM
ZX10R shock swap red5 SV Talk, Tuning & Tweaking 4 02-07-06 07:05 PM
ZX10R K6 Shock andyaikido For Sale - SV's and SV related items 2 29-05-06 10:49 PM
