Old 15-06-07, 10:24 PM   #1
Biker_Billy
Default Valve Clearances - How 'Ard?
Hiya,
Thinking about checking the valve clearances on the SV tomorrow - just wondering how easy it is to do yourself?
I have the Suzuki service manual, and all the tools I need (I think) - just don't want to pay the garage £150 to check them if its something I can do myself.
Fair enough, if they do need adjusting, I'll book her in, cos it might be a job too far...
Cheers,
Billy.
Old 16-06-07, 08:06 AM   #2
toonyank
Default Re: Valve Clearances - How 'Ard?
Originally Posted by Biker_Billy View Post
Hiya,
Cheers,
Billy.
Well if you can check the clearance you can set the clearance. You've then done 90% of the work (well 75%).
I haven't done this yet on mine but I plan too. If it's anything like my old 1993 gixer then it's just an adjusting tool basically a inversed allen key not too expensive and a spanner to tighten the locking nut the only thing is be carfull not to over tighten.
Just remember like any four stroke when in doubt about the clearence it's better the gap to be over than under. You don't want the valves to be floating and not seating as that will burn the exhaust ones up.
The good thing is you've only got eight to do not 16 like the fours.
Old 16-06-07, 08:13 AM   #3
chazzyb
I understand it's cams-out to change shims...
Old 16-06-07, 09:30 AM   #4
rictus01
rictus01's Avatar
Indeed it is a cams out job, unfortunatly most bike motors these days don't have rockers (the ones you can adjust with a spanner/screwdriver) and are of the bucket & shim type, under an inverted metal cover (bucket) is a small disc of metal (shim) which is changed to alter the gap.
Whilst it's a fairly easy process for checking the clearances (made even easier on the SV by having the second head as a guide if you need it), adjusting them will mean removing the cams to expose the buckets underneath, once that is done you have to lift them off and measure the thickness of the shim and replace it with one which will make the clearance correct, this needs doing for each valve, when all have been done the cams need re-installing and the timing set, then repeat for the other head.
Not brain surgery but perhaps a little more complex than an oil & filter change, don't get it wrong as it could turn very expensive very quickly, so check everything Twice
Cheers Mark.
Old 16-06-07, 10:42 AM   #5
chazzyb
Cheers Mark.
So, it's a 'no beer in the garage' job then?
Old 16-06-07, 12:01 PM   #6
you can have beer in the garage, just non alco. my blokes words at the prospect of buying an sv with 28000 on it were ' if you think i'm attemting to do those again you can @?"* off'. He did on suzy the first time and vowed not to do it again. The black one came with them already done fortunately for me, or is that him?
Old 16-06-07, 01:53 PM   #7
toonyank
Oh how times have changed I like the old way best
Old 16-06-07, 02:35 PM   #8
chazzyb
My SV's done 28000 now. It's time I checked the valves. I've, er, been procrastinating since, oooh, forever!
Old 16-06-07, 02:47 PM   #9
zunkus
Valve Adjustment SV650
This might be of some help...
http://www.madisonsportbikes.com/for...ead.php?t=1097
Old 17-06-07, 02:48 PM   #10
The 'old way', that is; screw and locknut, was easy it's true, but needed a whole lot more adjustment - swings and roundabouts.
I know a 100,000+ mile SV upon which five of the eight valves have never needed adjustment, that's just never going to happen with screw and locknut adjustment for the valves.
Valve clearances - how do you know? SUPERSTARDJ01 Bikes - Talk & Issues 19 09-05-09 05:16 PM
Valve clearances - K3 Lozzo SV Talk, Tuning & Tweaking 1 24-07-08 09:24 AM
Valve Clearances DanAbnormal Bikes - Talk & Issues 31 07-02-08 06:22 PM
Doing the valve clearances... instigator SV Talk, Tuning & Tweaking 7 16-10-06 10:08 PM
Valve Clearances HELP TSM SV Talk, Tuning & Tweaking 25 05-04-06 09:58 AM
