Old 19-06-07, 10:00 AM   #1
Gnome
Default Common problem?
Leaky fuel tanks?
The SV i'm about to have off my bro, has got 2 leaks.
One he's tried to patch up in the past, which now just results in petrol dribbling out, and the other is a pin-hole sized leak, and results in a steady stream of petrol coming out.
Now, to me, this is a new tank job, unless he can clean it up and get it welded, but the other problem being, he'd left it sat upside down in the shed. Not normall a problem, but it was a third full of petrol, which means it started to come out the filler cap, and has attacked the paintwork/ laquer, turning it green!
Old 19-06-07, 10:15 AM   #2
gettin2dizzy
Default Re: Common problem?
Never ever heard of it!
Old 19-06-07, 10:17 AM   #3
Gnome
It's a curvery model.
Seen one on eBay now, exactly the same colour, with the same problem.
Read somewhere it's to do with the breather getting blocked, and water collecting in the tank?
Old 19-06-07, 10:28 AM   #4
gettin2dizzy
Theres certainly a history of water getting in to the tank! Suzuki quality as usual Tanks can be cheap though, frequently check the for sale section here though, there's normally a curvey being sold for parts.
Old 19-06-07, 11:37 AM   #5
Sadly this is more common on the SV than most bikes, nothing to do with the quality of manufacture as such, just that the drain holes get blocked and never get cleaned out. If the bike stands for a while the water in the tank will collect at the lowest points and rust the tank out. as an example see here: Click
Also this thread with some photos that may well show similar damage to that which you have found: Click
Old 19-06-07, 01:47 PM   #6
andy
It is not just the drain getting blocked, the design is tight as it exits the tank and it can get kinked - hence causing a block!
Old 19-06-07, 10:08 PM   #7
Indeed, hence this:
Most commonly the problem is the rubber hose that leads from the stub on the bottom of the tank, right at the rear by the hinge, is kinked. Carefully arrange the hose so that it's not kinked when you drop the tank.
In the first of my quoted posts.
RIP Common Sense kd sweety Idle Banter 1 29-03-08 09:42 PM
The common cold DanDare Idle Banter 10 22-02-08 09:28 PM
leak from right-hand crankcase/side cover- common problem ? chriskk SV Talk, Tuning & Tweaking 9 09-10-07 11:27 AM
common problem, but wrong place localhost SV Talk, Tuning & Tweaking 7 29-03-06 10:14 PM
Common as muck ? Stig Soho Massive 15 18-10-04 12:22 PM
