Old 20-06-07, 11:37 AM   #1
hovis
Default replacing scorpion can with standard can?
my bike came with a scorpion road can, which i replaced with a race can, but can i now put the standad can back on, or will it not fit?
Old 20-06-07, 11:40 AM   #2
Baph
Default Re: replacing scorpion can with STD
I'm confused, why is this a problem??
Surely the cans will fit the same link pipe?? So where's the problem?
If they don't fit the same link pipe, then both link pipes should fit the header pipes. So again, where's the problem??
Old 20-06-07, 11:59 AM   #3
hovis
i mean the stanard suzuki can,
Old 20-06-07, 12:04 PM   #4
should do, when zorstec fitted the art can on suzy they made it so we could put the standard back for 'mot' purposes, with no diificulty
Old 20-06-07, 12:32 PM   #5
Baph
My scorpion came with an adaptor plate for just such use.
Old 20-06-07, 05:23 PM   #6
skint
As Baph says, simple if you have the link if not you will only have a butt joint between lead pipe and silencer.
Is that the shortest reply you have ever done Baph?!
Old 20-06-07, 05:31 PM   #7
Baph
No.
Old 20-06-07, 07:57 PM   #8
skint
No.
Battery needs replacing? maclovin SV Talk, Tuning & Tweaking 5 17-02-09 05:55 PM
scorpion oval can or the scorpion street extreme jans1971 Bikes - Talk & Issues 6 03-02-08 10:41 PM
Air Filter - Does it Need Replacing I'm_a_Newbie SV Talk, Tuning & Tweaking 10 08-10-06 08:04 PM
Replacing bearings andyb SV Talk, Tuning & Tweaking 12 09-05-06 02:59 PM
Replacing used R&G bungs... rock Bikes - Talk & Issues 9 28-04-06 02:10 PM
