Scotland's most dangerous road is on the outskirts of Glasgow, a survey of fatal crashes and accidents has shown.
The A726, connecting to J3 of the M77, near the city's southside and Paisley, has the worst accident record in the country. The stretch of road is only four miles long but had 37 serious or fatal collisions between 2000 and 2005. Researchers found that the second most dangerous road in Scotland was the A85 between Perth and Crianlarich which saw 114 deaths or serious injuries over its 54 miles, between 2000 and 2005. http://news.bbc.co.uk/1/hi/scotland/...st/6238024.stm pete
SV650 Sport in Black MZ saxon tour 301 Previous bikes SV650 Naked BMW 650cs Scarfer MZ RT 125 4 stroke |
I really do not understand why so many people have issues with the perth - crainlarich road. You'd have to be either short sighted or just a plain speed demon to make a mistake on it, it's a great twisty road for just coasting along going side to side good for learning how to control the sv's 'smoothness' the only thing i dont like is the dodgy tarmac on some of the corners.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
Are HID (high powered) headlights road legal? | lapoderosa | SV Talk, Tuning & Tweaking | 25 | 01-10-08 07:32 AM |
Would you risk . . . | Supervox | Idle Banter | 12 | 29-08-07 07:24 AM |
R1 does high speed run over 35km on SA road...(vid) | Jdubya | Idle Banter | 11 | 18-06-06 09:38 PM |
Should I risk it | Dicky Ticker | The Essex Lounge | 17 | 28-02-05 11:12 AM |
CCC road legal, high level | northwind | Exhausts | 1 | 15-08-04 07:24 PM |
