has anyone got an easy way to get warning stickers off tank and fearing
Hair dryer or heat gun if you've got one.
Warm the sticker, pick a corner up and blow the heat under the sticker while peeling it off slowly. WD-40 should clean off any residue left on the paintwork. |
My experience is don't bother. The mess you will be left with is a nightmare. See my previous thread on the topic.
#5 | |
Knob faced knobster
I've done this a few times now using a hair drier and yes a bit of sticky residue gets left behind but as andyaikido has said WD-40 will get that off
2011 Speed Triple 1050 |
I peeled off the translucent top layer and then I rubbed the sticker with a bit of cloth I had soaked in petrol. After a few minutes the petrol made the sticker go soft and I was able to peel it off.
When I had got it off I wiped the area over with petrol again and then with WD40 cleaned it up nicely.
thanks nice tip
When I de-stickered my bike, the ones that came off most easily were after I had left my (black) bike parked in the sun on the drive after a ride for an hour or so (so it was quite nicely warmed up). I just picked at the corner with my fingernail and managed to get the edge up. Then I peeled it off and the whole thing came away in one go. This only worked on 2 of the stickers mind, on the other ones, I only pulled the top layer away and ended up having to use 'goo remover' (cleaning product) to get the rest off.
#9 | |
Anybody got a HG Tricky jacket? | jamesw1024 | Riding Gear | 12 | 20-04-08 09:37 PM |
Tricky question.... | Caddy2000 | SV Talk, Tuning & Tweaking | 11 | 27-09-07 06:35 PM |
Any swimmers on here ? A Tricky challenge | tricky | Idle Banter | 23 | 19-04-07 02:57 PM |
Hmmm....looks tricky | TC3 | Idle Banter | 3 | 21-05-06 08:34 AM |
a tricky one . mmm | Warren | Bikes - Talk & Issues | 21 | 30-10-04 12:29 PM |
