Old 11-07-07, 05:15 PM   #1
steveg
steveg's Avatar
Default replacement chain cost
Hi ,
My original chain has given up the ghost , first 14 k was ridden without scotoiler , fitted scotoiler at 14k & now up to 19k , when adjust tightest part of chain correctly other parts of the chain are too loose .
Been quoted 130 quid to supply & fit a gold x ring chain , chain is 100 & fitting 30 quid , seems a fair price to me , what do you recon ?
Hoping to get 30 k out of this chain with the scotoiler.
Cheers Steve
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 11-07-07, 05:19 PM   #2
hovis
Default Re: replacement chain cost
i would fit new sprockets as well
Old 11-07-07, 05:22 PM   #3
steveg
steveg's Avatar
Hi Hovis
Forget to mention the price includes chain & sprockets .
What's the difference between O ring & X ring chains ?
Do the X ring chains last longer ?
Cheers Steve
AKA Papa Smurf
Old 11-07-07, 06:02 PM   #4
Search on 'X' and 'O' ring differences - there's info on here.
£100 ish pounds is a typical price for a C&S.
Old 12-07-07, 06:44 AM   #5
toonyank
Originally Posted by steveg View Post
Hi ,
Cheers Steve
Check Wemoto here:
http://shop.wemoto.com/index.dyn?oid=5835676
They've got good prices and they're a good bunch of lads good service and you get a free key chain with every order. I've got a dozen key chains now
They've got a good deal on a chain and sprocket kit.
Old 12-07-07, 08:30 AM   #6
Spanner Man
Morning all.
As said many times before there are so many makes of chain, & all the makers do several different grades. Therefore just because a chain is gold & may have 'x' rings, doesn't necessarily make it better than a normal chain of a higher grade with 'o' rings......There's little or no advantage in having an 'x' ring chain over an 'o' ring chain provided it's kept lubricated.
My advice would be to go for a Tsubaki SG (normal) or SGX (gold 'x' ring) from B&C express 01522 791369. They also do either JT steel sprockets, or Renthal. If you go for Renthal get the hard anodised rear & not the standard alloy. Well worth the extra couple of quid.
Forgot to mention that B&C list the APX chain as standard for the SV650, make sure you ask for the SG or SGX.
Cheers.
Spanner Man
Replacement chain adjusters lazymanc SV Talk, Tuning & Tweaking 0 08-04-09 12:03 PM
Chain & Sprocket replacement inspectorgadget SV Talk, Tuning & Tweaking 54 27-11-07 12:31 PM
Do I have to take off the swing arm for chain replacement? budrosmith SV Talk, Tuning & Tweaking 18 29-01-07 06:57 PM
Replacement Chain and Sprockets sharriso74 Idle Banter 7 22-05-06 11:51 AM
chain and sprocket replacement sv650gerbrit SV Talk, Tuning & Tweaking 5 11-05-06 09:48 AM
