Old 12-07-07, 08:04 AM   #1
Gnome
Default Curvey seat...
Probably me being a dumbass, but how does the front seat on a curvey attach to the bike?
Obviously the key lock operates the rear seat, but does the front seat just bolt in place?
Old 12-07-07, 08:06 AM   #2
hovis
Default Re: Curvey seat...
remove the 2 black side panels, then there is a bolt each side
you will need 2 allen keys not sure of the size
Old 12-07-07, 08:09 AM   #3
Gnome
Ah right.
When I got the bike, both these panels were hanging by the ir upper bolts, so I'll grab a couple of stainless bolts from my collection and bolt it in.
Cheers Hovis!
Old 12-07-07, 08:21 AM   #4
petevtwin650
Technically you don't need remove the panels. Just undo the allen bolt and hinge them gently backwards to allow access to the seat bolt. If you do wish to totally remove the panels then the Suzuki plastic "rivet" needs removing. To remove these, push the small inner pin through the rivet and then pull the rivet free.
If you are using none OEM bolts be aware that they have a step in them to stop breaking the panel if you tighten them up too tight which you won't have on a standard bolt.
Old 12-07-07, 09:23 AM   #5
chazzyb
The trim clips (plastic rivets) may well be long gone anyway.
Old 12-07-07, 01:54 PM   #6
ejohnh
I lost the black plastic rivet things the first week I got the bike (sept 06). Never replaced them. Seemed a bit pointless to me.
Old 12-07-07, 02:27 PM   #7
hovis
first i knew about them?
Curvey front seat trudd Stuff Wanted 2 25-07-07 10:13 PM
curvey gel seat hovis Stuff Wanted 1 18-06-07 05:43 PM
Curvey Gel Seat Luckypants For Sale - SV's and SV related items 10 12-06-07 12:50 PM
Gel seat for curvey derbybiker For Sale - SV's and SV related items 0 06-11-06 07:33 PM
Curvey seat Jase22 Stuff Wanted 8 28-06-06 08:21 AM
