Old 19-07-07, 09:48 AM   #1
mdcvjd
Default Help - Dead Bike.
HI Everyone,
I need your help figuring out this problem I have with my 2003 sv. I was trying to wire new led turn signal and I think I caused a short circuit. All the fuses are fin, but I can't start the bike. There is nothing at all when I turn the key ?
Could the side stand/turn signal relay be damaged ??
Thanks for your help..
Old 19-07-07, 10:23 AM   #2
FreshAL
Default Re: Help ! Dead BIKE
1) Do any of the dash lights come on at all when you turn the key?
2) Have you got an alarm?
Datatool alarms (and others) have a master fuse which kills all the electrics. Usually hidden under the battery cover or rear seat. You should have a fitting diagram with the alarm paperwork.
Old 19-07-07, 11:38 AM   #3
gettin2dizzy
Yep - theres an inline fuse too. Look for a rubber part in the wire. Whereabouts are you based?
Old 19-07-07, 01:43 PM   #4
mdcvjd
Thanks for you help.. I will have the relay tested first. Where can I find the inline fuse ?
thanks again.
marc
Old 19-07-07, 01:51 PM   #5
mdcvjd
There are no dash lights when I turn on the ignition. nothing at all .. It was working fine before I tried to connect after market turn signla...
Old 19-07-07, 02:10 PM   #6
gettin2dizzy
have you checked every fuse? have you disconnected the indicators? If you have an alarm it'll be more complicated. If you mention where you live someone may be willing to call by to have a look for you. (for a cup of tea )
Old 19-07-07, 02:32 PM   #7
Slim666
Default Re: Help - Dead Bike.
As well as checking the fuses under the seat have you checked the 30amp main fuse behind the black trim pannel that you take off to get to the seat bolts on the right hand side?
Dead Bike. Grinch SV Talk, Tuning & Tweaking 21 07-01-09 11:52 PM
My bike is dead shonadoll Bikes - Talk & Issues 12 14-08-08 10:08 PM
Dead Bike... MidgetMoose Pennine Massive 6 07-09-07 07:22 AM
Bike dead Red ones Bikes - Talk & Issues 17 15-05-07 06:22 PM
Dead Bike seandixie Bikes - Talk & Issues 24 07-10-06 03:11 PM
