Old 23-07-07, 12:13 PM   #1
Muzzy
Default LED indicator advice
Hi all i have bought some LED indicators for my new tail tidy, i have also bought the resister thing to go with them but i have not got a clue where it wires into the indicators.
i obviously have 2 indicators and both have two wires coming off ready to wire to the existing but the resister thing is a little black box with only two wires coming out of !!!!!
I have not got a clue
Old 23-07-07, 12:26 PM   #2
Default Re: LED indicator advice
when i had this problem northwind did me a lil diagram of how to do it.
Old 23-07-07, 12:37 PM   #3
Stu
Trinity
Stu's Avatar
In parrallel across each indicator.
Old 23-07-07, 12:46 PM   #4
dirtydog
Knob faced knobster
dirtydog's Avatar
like so.
excuse the rubbish drawing
2011 Speed Triple 1050
Old 23-07-07, 02:28 PM   #5
sorry it wasnt northwind it was dirtydog ^^ same diagram
Old 23-07-07, 02:33 PM   #6
SoulKiss
SoulKiss's Avatar
Only problem with the advice so far is that what he has sounds more like a Flasher Relay then a resistor - which is im my opinion a better solution to flash rate issues.
Post a pic of the unit so we can see what it is and advise accordingly
Old 23-07-07, 04:19 PM   #7
a new variable flasher relay will do the same job.
Old 23-07-07, 08:05 PM   #8
Philbo
You can add the resistors at any point in the circuit, it doesn't have to be anywhere near the actual indicator. Althought you do have to make sure your using the correct wires!
Old 23-07-07, 08:25 PM   #9
lancasterlad
ive just put some led's on mine and there flashing to fast i just want to know where on the bike is the flasher relay? as im buying the one for leds in the morning.
Old 23-07-07, 08:35 PM   #10
pointy or curvey?
indicator advice dave1701 SV Talk, Tuning & Tweaking 2 11-05-08 09:24 PM
Indicator Q Davido Bikes - Talk & Issues 9 16-01-07 09:43 PM
indicator? kwak zzr Stuff Wanted 3 03-12-06 09:26 AM
WTD: Bar End and Fat OEM Indicator Freeloader Stuff Wanted 3 25-02-06 08:44 PM
Indicator / belly pan advice please! Carl SV Talk, Tuning & Tweaking 6 01-01-06 06:02 PM
