Old 27-07-07, 03:26 AM   #1
veetwin
Default Broken clutch plate
Hello all
I have a clutch problem with my sv650 s k1 (2001)
A while back i couldnt select neutral from first after stopping
at traffic lights or junctions etc if i stopped the engine it flicked up
fine. I put it in the shop and they discovered that a piece about one inch long had snapped on one of the secondry clutch plates this was replaced
and all was ok for about 3 weeks but now its started again sometimes just needs a bit more force other times just wont move when this happens clutch is also dragging like the first time.
Bike is bog standard and as far as i know all obvious stuff checks out
fine ie- clutch cable adjustment/chain tension/gearbox oil etc
All other gears are fine up or down its just this first to neutral when
not moving
Any thoughts greatly appreciated
Old 27-07-07, 07:05 AM   #2
Default Re: Broken clutch plate
If you're having trouble getting neutral then the clutch is still dragging.
I assume by secondary plate you mean plain plate? That is; not the plates with the inserts in - the friction plates.
Was just one plate replaced? I'd be checking the lot - I strongly suspect there's a warped plate in there somewhere. Another possibility is that the broken plate has damaged the hub and is causing the plates to hang on it and not separate cleanly.
Old 27-07-07, 07:58 AM   #3
Viney
I wish my clutch worked!
Old 27-02-08, 03:39 PM   #4
veetwin
Better late than never with this update.
Put the bike back in a different shop and after a
bit of adjustment the problem is solved.
Just like that,
Anyone looking for a brilliant SV mechanic
call BBS BIKES in Stone near Dartford 01474833553
this guy knows his onions highly recomended.
Old 27-02-08, 04:24 PM   #5
Viney
Can he source some moeny for me as well? I know what wrong with mine, just need the cash.
Glad you got it sorted mate.
Old 27-02-08, 04:57 PM   #6
Brooga
Just like that,
Do you know exactly what it was he adjusted? Im having similar symptoms with my 02 curvy.
Old 27-02-08, 09:48 PM   #7
Pushrod mechanism probably, sid squid has done a good writeup on how to adjust it
Old 28-02-08, 07:53 PM   #8
Brooga
Cool Re: Broken clutch plate
Ohh, cool gonna look for that.. I may very well be back to ask for a direct link because im hopeless! hah
Rubber dampers on clutch plate nicky-jano SV Talk, Tuning & Tweaking 8 06-05-09 11:50 AM
What causes broken clutch plates? nicky-jano SV Talk, Tuning & Tweaking 5 07-04-09 11:08 PM
Broken cam plate detent instigator SV Talk, Tuning & Tweaking 9 03-10-06 06:53 PM
Clutch Driven Plate trudd Stuff Wanted 0 08-08-06 10:17 AM
Is my clutch #|_|(k€d ? (broken) SpankyHam SV Talk, Tuning & Tweaking 12 12-05-06 06:04 PM
