Old 31-07-07, 11:59 AM   #1
600+
Default Cold Water Hammer
I know we have a couple of plumbers on here so any help would be much appreciated.
Had to change my kitchen tap about a year ago and since I have had cold water hammering Will only stop if you open the cold water fully and will not happen if you have another tap running.
I have tried closing down the main water supply under the sink and that helped but then the water pressure in the shower upstairs was pooh
Any ideas? What can I do to sort it out? Is it the tap?
Old 31-07-07, 01:44 PM   #2
chazzyb
Default Re: Cold Water Hammer
As I understand it, it's down to a pressure wave being reflected back and forth in the pipe work. Runs of pipes that aren't supported properly don't help at all.
I found this http://www.factsfacts.com/MyHomeRepair/PipeNoises.htm which might be helpful.
Old 31-07-07, 02:19 PM   #3
600+
I've read these docs on the net but all require installation of stuff etc etc.
Question is why would it happen when I changed the tap you see
Old 31-07-07, 02:38 PM   #4
rigor
You've installed a tap with a Poltergeist in it!
HTH
Old 31-07-07, 03:13 PM   #5
Razor
Whip the washer out again and make sure you haven't pinched it and deformed it when you tightened up. The loose pipework is usually where to look otherwise.
I have hot water pipes that creak and groan as they heat up, right under the bath surround. There's no way I'm stripping everything to sort them...
Time to sell house!
Old 31-07-07, 04:21 PM   #6
our old house used to do it when the stop tap wasnt fully open.
Old 31-07-07, 05:50 PM   #7
600+
I shall take the tap off in the weekend and check the washers
Old 31-07-07, 05:57 PM   #8
dirtydog
Knob faced knobster
dirtydog's Avatar
As Razor said check the tap washer and that the pipe is properly clipped to the wall
2011 Speed Triple 1050
Old 31-07-07, 09:28 PM   #9
timwilky
timwilky's Avatar
Water hammers can be impressive. We had one cause a major outage at a power station in India when it fractured cooling water pipes. simple because a valve shut too quickly
Not Grumpy, opinionated.
Old 31-07-07, 10:30 PM   #10
Generally it's down to insufficient pipe support, it can be worsened by ceramic disc taps - they shut quite abruptly and cause the quick static pressure rise that sometimes causes the hammer in pipework that can move.
If the pipes can't be suitably fixed, there are devices that can be fitted to the incoming main to reduce hammer, essentially they're in two forms:
1) A pressure reducing balanced valve, like the regulator on a gas bottle or a DV if you're a diver, (Jaques Cousteau apparently used a modified camping gas regulator for his first experiments in Scuba breathing apparatus).
2) A piston in a pipe with a spring behind it, when the pressure rises as a valve is shut the piston displaces and the slows the static pressure rise.
Recomend me a hammer... Grinch Idle Banter 41 15-01-09 05:48 PM
the cold kwak zzr Bikes - Talk & Issues 37 26-03-08 05:51 PM
Might aswell have a Hammer thread SteveH Idle Banter 2 06-11-06 01:29 PM
How to get it going when it's cold. Mark_h SV Talk, Tuning & Tweaking 10 01-01-06 09:09 PM
It's cold out there Moriarty Bikes - Talk & Issues 9 24-02-05 08:39 PM
