Hi
Just adjusted clutch cable , to get correct adjustment , had to adjust lower adjuster ,bottomcable adjuster lock nut is flush with end of thread , I guess thats as much adjustment as its got ? bike had done 20 k miles , and does a lot of filtering / town riding therefore alot of clutch work , any idea of normal clutch cable life / cost for the sv? cheers Steve
ex - red sv650s 06 reg Now Triumph sprint 1050 ABS 05 Reg AKA Papa Smurf ![]() |
You probably need to adjust the clutch push rod action as wel, have a look in the manual section.
too may people mistake the cable adjustment for the clutch adjustment
loosen cable completely, take of front sprocket cover, adjust clutch (locknut & rod) then adjust the cable trying to adjust the clutch with the cable adjusters will only make the clutch go out of adjustment, or prematurely wear the cable FWIW, my original clutch cable was replaced with 92,000 miles, clutch fibre plates & springs replaced at 102,000 miles. at 135k I still have the original steel clutch plates |
Ah but Randy me old fruit, sitting doing considerable milage on highways, you are not exactly changing gear and using the clutch as say, a town only rider. That said, i got 45k out of my clutch plates and steels.
The cable however, a lot less. had 3 cables in 52k |
#5 | ||
To adjust your clutch: Quote:
#6 | |
Not sure why the cable will wear more if you do this? As far as I know the only reason to adjust the clutch at the pushrod, then the cable, is to maximise the adjustment available on the cable, which is the easiest to do, and hence reduce effort in the long run. If the cable gives you enough adjustment to get the desired freeplay at lever, then that is all you need to do. If both the adjusters run out (as the original poster was questioning) then all this means is you need to do the push rod, then the cable, as SidSquid so correctly says. The cable adjusters reaching end of travel are an indication of cable stretch (and clutch plate wear) but not necessarily an indication that the cable needing changing - look for fraying, especially at the nipples, if it looks OK then just adjust it all properly and keep on using it, give it a regular oil and it should last a very long time..... |
less than 5% of my 135k are highway miles , I have more miles using the SV as a dirtbike, 1st & 2nd gear slipping clutch standing on pegs in loose rocks, mud & gravel
#8 | |
re-read what SidSquid just posted Last edited by RandyO; 06-08-07 at 10:44 PM. |
Pointy clutch cable | simesb | Stuff Wanted | 0 | 11-04-09 03:16 PM |
clutch cable | DoubleD | Stuff Wanted | 1 | 01-05-08 11:17 PM |
Clutch cable | 21QUEST | For Sale - SV's and SV related items | 1 | 03-04-06 12:03 AM |
new clutch cable problems | nakedCDN | SV Talk, Tuning & Tweaking | 3 | 16-04-05 08:00 AM |
