Old 15-08-07, 06:45 PM   #1
leemole
Exclamation loose brake disc
one of the discs on the front is movin a 1mm side ways but not forward or backwards. A few of the round metal rings on the inside are in half. Should i still ride as its my only way to work at the mo
Old 15-08-07, 08:01 PM   #2
Blue_SV650S
Default Re: loose brake disc
I think you know the sensible answer here don't you
I am not quite sure what you are saying has happened ... have some of the 'buttons' lost their retaining clips and starting to slide out??!!? If so FFS, NO don't ride it!!
Old 15-08-07, 08:13 PM   #3
leemole
yeah its the buttons holding the disc to the mount . Ive posted a wanted ad so hopefuly.... cheers
Old 15-08-07, 08:25 PM   #4
Blue_SV650S
Ouch!!! How many buttons remain in place???
Is it a standard SV disc? I just can't see how they have come out as they are beveled over ... worrying ... out of interest, take a pic ...
Anyhoo, yep, deffo don't ride it like that.
Old 15-08-07, 08:27 PM   #5
TSM
The Sick Man
TSM's Avatar
They are a spring type washer, bent into a U shape, may look like they are in half but actualy pushing the bobin so it does not rattle about.
Old 15-08-07, 08:30 PM   #6
Blue_SV650S
Ahhh ... yes, I misread/understood that as 'half in' not 'in half' ...
In that case yes perfectly normal ... take a pic though and post it up though leemole just to make sure we are all on the same page!!!
Old 15-08-07, 08:43 PM   #7
leemole
cant get a pic yet bit dark but the left has prob twice the movment of the right
thanks for the up
Old 16-08-07, 09:00 AM   #8
Mousetrapper
Default Re: loose brake disk
I can't say if you should ride it like that, but I did for a week or so before I got the disc replaced under warrenty. Not really very helpful I realise, still if you are going to ride it be gentle!
Old 16-08-07, 11:16 AM   #9
jambo
jambo's Avatar
If all "buttons" are present and correct, and in securely, and there happens to be a little movement between the carrier and the braking surface of the disc then it's ok to ride on for now. If any of the buttons which hold the 2 parts of the disc are missing or dammaged it is not ok.
HTH
Jambo
Brake Disc Loose. CB1ROCKET Bikes - Talk & Issues 17 15-05-08 09:27 AM
Disc loose on carrier Fizzy Fish Bikes - Talk & Issues 6 13-08-07 01:18 PM
Disc Rotor Loose At Rivets!!!!(Again) NedSVS SV Talk, Tuning & Tweaking 1 12-03-07 11:26 PM
Disc Rotor Loose At Rivets!!!! NedSVS Tyres 4 12-03-07 10:34 PM
