Old 18-08-07, 06:02 PM   #1
Default Throttle valve link arms
This is actually about dizzyblondes black bike, but I'm curious about it;
The arm that links the front and rear throttle valves together has worn on the pivots to the extent that the balancing screw is wound all the way in, and the rear throttle is still fully closed. Hence it's not possible to get the carbs balanced up.
So, can you get the arm as a part? What about if it is the lever on the end of the butterfly shaft thats worn?
My first instict is just to buy a spare set of carbs, but what are everyone elses thoughts?
Chris
Old 18-08-07, 06:04 PM   #2
Razor
Default Re: Throttle valve link arms
I'd get a spare set of carbs. Was a time they were pretty cheap but are getting harder to find in decent condition.
Old 18-08-07, 06:09 PM   #3
Another thought is bodge the adjustment so the balance screw could go further.
(reaches for hammer....)
Old 19-08-07, 12:41 AM   #4
svrash
I had the exact same problem a while ago, i had a set of carbs spare and had to replace the arm and butterflys from the spare set because the pivits on the levers attached to the butterflys had worn also so i'd find a spare set of carbs if i were you
The problem you'd have with bodging the screw will be you'd still have play in the arm/pivits and still have uneven balance when you move the throttle
Old 19-08-07, 06:36 AM   #5
John Burt
It is repairable but its a lot of work, bush the plate and make/build up, sleeve the shafts. Probably easier to buy a set of sh carbs.
Farmers arms 20.5.09 stewie The Border Patrol 18 21-05-09 08:52 AM
So blingking shiny my arms ache!! sv-robo Photos 34 22-09-08 04:16 PM
Throttle Valve Synchronisation - help! Aidan SV Talk, Tuning & Tweaking 11 05-11-07 08:20 PM
Lysley Arms, Pewsham glade South & West Surfers 3 13-06-06 08:51 AM
The Hatcham Arms 92 New Cross !!! hall13uk The Good The Bad and The Ugly Pub and Cafe guide 0 04-03-05 04:46 PM
