Old 20-08-07, 11:19 PM   #1
svrash
Default Gear linkage end
the bit that attaches to the gear box shaft after the rod. Preff with non-rounded teeth
Old 22-08-07, 11:10 PM   #2
Ter
Default Re: Gear linkage end
Think I may be able till help you out fella - but I'm away until Tuesday - I'll look back on here then to see if you still need it,
Old 23-08-07, 09:07 AM   #3
svrash
Cheers Ter
Sourcing gear linkage Demonz Bikes - Talk & Issues 7 30-06-08 04:45 PM
Gear linkage. Jester666 SV Talk, Tuning & Tweaking 5 05-07-07 03:17 PM
Gear linkage - will one from an SV1000 fit? Rock Hopper Penguin SV Talk, Tuning & Tweaking 6 03-06-07 06:41 PM
Gear shifter linkage rod Razor SV Talk, Tuning & Tweaking 5 05-01-07 11:26 PM
Gear Linkage Adjustment - Should it be necessary ? leegriffiths128 SV Talk, Tuning & Tweaking 1 05-04-05 08:55 PM
