Old 01-09-07, 02:19 PM   #1
Tim in Belgium
Default Fuel light won't stop flashing.
Well I came out of a shop and got on the SV, the fuel light started flashing almost immediately, it was over 110 miles so no big surprise, I then went and filled up, and when I started the fuel light was still flashing. I drove a couple of miles and it briefly stopped, but then I pulled alongside a Ducati on the hard shoulder to check he was ok (minor electrical problems). I didn't stop the engine and the fuel light started to flash again and proceeded to flash for the 7 miles home.
Any ideas why it won't turn off with a full tank of fuel? Is it goosed or just a gremlin in the works?
By the way it's an '01 curvy.
Cheers,
Tim
Old 01-09-07, 03:57 PM   #2
ASM-Forever
Default Re: Fuel light won't stop flashing.
Electrical gremlin surplus, from the Duke, has unfortunately infiltrated your bike....i have little to suggest other than not getting them wet.
Old 01-09-07, 05:16 PM   #3
Maybe a short, if the red/black or the black/green wires have grounded out then that would cause it, and would also explain why it's intermittent.
The switch has 3 wires, when "on" the current is allowed to pass to earth, check for continuity between the 2 power wires and earth, if there is with a full tank then that would say to me that the sender unit has failed.
Not sure how they work, but this seems like the most sensible way.
You could also just unplug the sensor, if the light goes out then this would point to a fault on the sensor.
Chris
Old 01-09-07, 05:54 PM   #4
Tim in Belgium
Cheers for the help, will give it a go tomorrow, just been out on the Helmsley TT in a bid to cure it, no effect as it's still flashing, but had fun.
Old 02-09-07, 02:04 PM   #5
Tim in Belgium
Looks like a faulty sensor, bit annoying as I'm off Friday evening for two weeks, are well, will just have to use the trip meter and guess my fuel!
Old 02-09-07, 05:21 PM   #6
http://cgi.ebay.co.uk/SUZUKI-SV650-S...QQcmdZViewItem
Fill your boots mate its only a 10-20 minute job to swap.
Old 02-09-07, 05:40 PM   #7
Tim in Belgium
Sweet, will ring them/buy it first thing tomorrow, hopefully I'll get it before leaving, got a spare morning at the ring if I can't fit it before leaving.
Old 02-09-07, 05:57 PM   #8
shouldn't be too hard to fit, if theres less than a gallon in the you should be able to turn the tank on its side so you don't have to drain it.
Remember to get a bit of PTFE tape for the threads
Chris
Old 05-09-07, 08:33 PM   #9
Tim in Belgium
Well, it stopped flasshing at approx 110 miles, the started again at 130 miles, filled it up and it stopped flashing, so looks like it sorted itself out, or the gremlin has been sucked through and burnt
Old 05-09-07, 10:52 PM   #10
Well at that I'd guess the sensor works by floats and the top one got stuck, if it happens again then maybe try hit the sensor with something.
(percussive maintenence )
When the petrol light starts flashing. RichT Bikes - Talk & Issues 20 17-10-08 06:35 PM
fi light flashing antony SV Talk, Tuning & Tweaking 1 09-03-08 02:30 PM
fuel light flashing how many miles till it runs out jans1971 Bikes - Talk & Issues 29 10-10-07 09:47 PM
clear tail light / stop light Lens for sale SVTONYB For Sale - SV's and SV related items 7 20-05-07 04:55 PM
Bike wont start - FI warning light flashing chunkytfg Bikes - Talk & Issues 6 05-06-06 05:18 PM
