Old 07-09-07, 04:14 PM   #1
markmoto
Default Lowering a pointy help please
Hi
Im after some info on lowering a pointy sv650 for a friend, am i right in thinking you can get longer dog bones and does anyone have any idea how much lower this makes the bike? also where can you get these?
Also is the only other option a modified seat?
How about dropping the forks through the yokes does this help matters?
thanks in advance.
Old 08-09-07, 06:48 AM   #2
Spanner Man
Default Re: Lowering a pointy help please
Good morning.
I don't know who does longer dogbones for the Pointy, but all rising rate rear suspension set ups have roughly a 3-1 ratio. Therefore if you increase the length of the dogbones by 10mm you'll lower the seat by roughly 30mm, & vice versa.
I've found that lowering the forks slightly lkess than you lower the rear to be about right. i.e. if you lower the seat 30mm, pull the forks through 25mm etc.
The best way of lowering the bike is still a replacement shock, Hagons do bespoke lowering shocks for just about every bike for around £300. Pricey but worth it I think.
You can always get the seat padding reduced too.
Cheers.
Spanner Man
Old 08-09-07, 07:09 AM   #3
MiniMatt
What the man with the spanner said Plus, get your friend to have a sit on an unmodified bike to begin with anyway, you may be suprised. With the preload set to "Special K" rather than "Cornish Pasty" weight (assuming your midget friend is also light on the pie scale) the suspension compresses enough for most dwarves. I'm 5'5" and can get one foot down flat, both down on tippy toes. Just have to be a teensy bit careful putting the left foot down on roads with a steep camber toward the drain
Old 08-09-07, 09:52 AM   #4
markmoto
thanks guys
Old 08-09-07, 11:12 AM   #5
fizzwheel
fizzwheel's Avatar
Liz got her longer dogbones for her K5 from her local Suzuki dealer, they sorted it all out for her and dropped the forks through the yoke to.
If you're dropping the yoke, dont go to far with it otherwise it will upset the handling 10mm I think is about as far as you can get away with.
Old 08-09-07, 12:26 PM   #6
Also, if you drop the front too far you can end up in a situation where the forks will hit hard parts before they bottom out. There was a guy on the ER6 forum who dropped his front by 4 inches, total cretin, then he went over a high kerb and bang, forks into yokes, broke his thumbs Same guy had been telling teh entire internetz how great this mod was, and how it made him superfast in a straight line
Old 08-09-07, 12:49 PM   #7
markmoto
great advice thanks guys! common sense surely tells you you cant drop the forks 4 inches no? ok maybe not the case with some people
Old 09-09-07, 09:23 PM   #8
kcowgergmm
well dogbones will work but why not go ahead and put an 04-05 gsxr 600-750 front end and shock on that lowered my bike some not that i needed it lower but dropping the forks and changing the dogbones and lowering the seat are the best way to go
Old 10-09-07, 12:16 PM   #9
LindaS
Hi
I've just bought a lowering kit for my new SV650 from ebay. The sell kits for 25mm and for 40mm, same price for each: £14.
I can look up the seller for you if you want.
Regards
Linda
Old 10-09-07, 12:18 PM   #10
markmoto
Originally Posted by LindaS View Post
Hi
Regards
Linda
If you wouldnt mind linda that would be great.
mark
Pointy Lowering kit hob For Sale - SV's and SV related items 4 03-12-08 08:11 PM
Lowering a pointy - any pointers? trinyquist SV Talk, Tuning & Tweaking 21 12-04-08 06:34 PM
Lowering my Pointy Shellywoozle SV Talk, Tuning & Tweaking 18 18-12-06 11:51 AM
Lowering a K3s pointy viner SV Talk, Tuning & Tweaking 3 12-09-05 02:41 PM
Lowering an SVS... Aaron_T SV Talk, Tuning & Tweaking 11 08-08-05 06:03 PM
