Old 10-09-07, 08:07 PM   #1
monkey
Default Quick question for anyone with a pointy and genuine seat cowl
I'm sending my old one to someone but can't find the grab rail at the minute. Am I right in thinking the bracket pictured below replaces the grabrail which incorporates the bracket for the seat to slot into? To put it simply do I need to send the bracket beolw with the infills and the cowl?
Answers on a leotard.
P.S. Check out the now rare FOPP bag and Scottoiler sticker on my company laptop.
Old 10-09-07, 08:11 PM   #2
Mr Toad
Default Re: Quick question for anyone with a pointy and genuine seat cowl
Yep
There should also be some replacement bolts and 2 large rubber washer thingies
cheers
Old 10-09-07, 08:21 PM   #3
SoulKiss
SoulKiss's Avatar
Yep you WILL need a grabrail or the rear seat wont stay on.
I just happen to have a spare pointy grabrail - you want it?
Old 10-09-07, 08:21 PM   #4
monkey
Originally Posted by Mr Toad View Post
Yep
cheers
Well the bolts on there were more than long enough to fit the seat again but I don't know which rubber washers you're on about?
Old 10-09-07, 08:24 PM   #5
monkey
No it's ok thanks I have got it on the garage but it's not at my home and it's not easy to find there. The seat fits ok for overnight and I can wobble it without it coming off or the alarm switch triggering. Cheers.
Old 10-09-07, 09:00 PM   #6
monkey
Bump ditty bump bump.
Old 11-09-07, 07:32 AM   #7
biccy g
If your mate does not want that bracket I will take it off your hands...
Old 11-09-07, 09:23 AM   #8
Mr Toad
You can see where the rubber washer thingies went from your pic - they've left a slight mark on the metal. You can use either that bracket & the fillets that are attached to it to clip the seat cowl into, or you can retain the original grab rail which will serve the same purpose
Old 11-09-07, 11:11 AM   #9
monkey
Well I must've been missing the rubbers cos those marks are where the bolts were!
It all fitted snug. Oh well.
Genuine Seat cowl Rhino Bodywork 23 02-03-12 08:10 PM
Quick car seat question Messie Idle Banter 5 18-06-08 01:25 AM
Genuine seat cowl question (pointy) rich_r SV Talk, Tuning & Tweaking 2 05-02-07 07:26 PM
seat cowl, k4 question hall13uk Idle Banter 20 04-02-06 04:38 PM
Seat cowl question TC3 SV Talk, Tuning & Tweaking 4 10-12-05 08:18 AM
