can anyone let me know the correct tyre pressure for the pilot road for my sv 650, 05 in lbs and kg and where can i buy a tinted visor for a shark helmet, thanks
Which model of SV650? Curvy or Pointy?
Try Racevisors.co.uk for a tinted visor. |
If it's an 05 it must be a pointy! I believe.
Just Ballast
You get so much conflicting information about the right tyre pressures. When we fitted the Pilot Road 2's, the guy put 36 front and rear. It just didn't feel right, so I actually e mailed Michelin to ask what pressures THEY recommended. Got an e mail back too.
Dear Lissa, Thank you for your e-mail and purchasing Michelin Tyres. We have the following pressure recommendation - Front at 34psi Rear at 36 psi There is NO requirement to increase for load/speed. Two Wheel Department Michelin Tyre plc We run at that two up, and have to say have never had so much as a twitch even in the wet.
If It's Too Loud, You're Too Old! I'd Rather Have Two Big Bangs Than Four Little Strokes |
I run mine at 36 front, 42 rear but these are on 12/70/17 front and 190/50/17 rear. The michelin website has a pressure chart on it as well you you can always have a lookon there.
HTH J |
Tyre pressures | AndyBrad | SV Talk, Tuning & Tweaking | 33 | 05-09-08 09:10 PM |
Road Tyre Pressures and tyre problems | G | Bikes - Talk & Issues | 14 | 05-06-08 03:29 PM |
Tyre Pressures | redbiker 954 | Mini-Twins | 5 | 21-02-08 10:25 PM |
Tyre pressures | mxm35948 | SV Talk, Tuning & Tweaking | 13 | 10-09-07 04:18 PM |
Tyre pressures - help! | benny | SV Talk, Tuning & Tweaking | 3 | 03-04-05 08:43 PM |
