Old 17-09-07, 05:25 PM   #1
Flamin_Squirrel
Default Monitor Woes
Recently bought a Xerox XM7-24w widescreen monitor. At the moment, the display is pretty poor, but I suspect this is due to plug and play drivers. Being as the company I bought it off seem to have forgotten to include the CD with the drivers on and the Xerox website is up the creek, I'm stuck.
The company I bought from isn't being too helpful, so I was wondering if anyone knows of any resources where I might be able to dig the drivers out from, before I have to start making demands for refunds etc.
Thanks.
Old 17-09-07, 05:37 PM   #2
TSM
The Sick Man
TSM's Avatar
Default Re: Monitor Woes
most monitors dont need drivers as they autoconfigure with the graphics card, as long as windows is set to Plug & Play Monitor then it should be ok, once the system has recognised the monitor the max res you can set on the slider will usualy be the best setting for the monitor in question, refresh rates of 50/60Hz are user dependent, both work, 50Hz is the pref though for most.
Old 17-09-07, 05:47 PM   #3
rigor
Drivers here?
http://www.xerox-displays.info/driver/XM7-19w.zip
Old 17-09-07, 05:55 PM   #4
Flamin_Squirrel
It's not the res I've got problems with. I seem to have different problems in different resolutions! Examples of issues I've got:
In 1680x1050 colours seem ok, but text looks wrong. Not to easy to describe, but the text looks 'fluffy', poorly defined, and the lines that make up the letters aren't uniform in size (as if parts of the individual letters are bold and some bits aren't).
In 1920x1200 The text looks ok, but the colours aren't at all right, and no amount of playing with brightness/contrast seems to fix it. Biggest problem (amongst others) I have with this is when I've got black text on a grey back ground (when you're selecting a option from a drop down menu (file, edit, view and so on) for example). The black text as a white gost, an outline around it, making it look very strange.
I've got another hdd with Vista installed on it which I'm gonna try, but I'm beginning to think it's fecked. Whatcha reckon?
Old 17-09-07, 05:55 PM   #5
Flamin_Squirrel
Originally Posted by rigor View Post
Dead link. Wrong monitor anyway.
Old 17-09-07, 06:14 PM   #6
ukgooner
I don't think that you get drivers for LCD monitors but different profiles. It maybe worth seeing if your graphics card has any software / driver updates available.
Old 17-09-07, 06:22 PM   #7
Flamin_Squirrel
It's been a while since I updated, so I'll try that.
Old 17-09-07, 06:42 PM   #8
Flamin_Squirrel
Hasn't worked. Think I'm gonna have to send it back. Sigh.
Old 17-09-07, 07:00 PM   #9
ukgooner
Before sending it back, uninstall the video drivers, reboot and use the default settings and see if you still have an issue with fonts, you can easily reinstall the drivers afterwards.
What video card have you got?
Old 17-09-07, 07:03 PM   #10
Filipe M.
Assuming you're plugging it via the usual 15 pin VGA cable and not a DVI input (couldn't be arsed to check if it even has one), check if there's an Auto setting somewhere in the monitor. It may be hidden in some adjustment menu.
I need a TFT monitor metalmonkey Idle Banter 2 24-04-08 03:20 PM
i got me a new monitor...... but hovis Idle Banter 27 25-01-08 05:40 PM
monitor........ which one? hovis Idle Banter 25 30-12-07 07:10 PM
PC/monitor help hovis Idle Banter 9 04-11-07 08:54 AM
Monitor Calibration Jdubya Idle Banter 5 18-10-06 02:06 PM
