Old 30-09-07, 07:44 PM   #1
Default Has anyone ever removed the whole petrol cap?
The reason I'm asking is because the metal ring trim on my petrol cap is flaking away. So I was thinking that I could buy a second hand cap then swap over the metal ring bits. That way, I can keep the same key.
But I don't know if you can remove only the metal bit.
Anyone know?
Old 30-09-07, 07:50 PM   #2
Brian
Default Re: Has anyone ever removed the whole petrol cap?
I've not removed the petrol cap completley nor the ring itself but:
I think I am right in saying that the bolts that hold down the metal ring are of different lengths.
So if you do remove the ring, make sure the bolts go into the same holes they came out of or you risk cracking the metal ring.
Old 30-09-07, 07:52 PM   #3
Brian
Yeah, just checked for ya:
http://www.suzukisv1000.com/faq/break_and_fall_off.htm
Hope that helps mate
Old 30-09-07, 07:54 PM   #4
SAMMY650
I took the whole cap off 3 days ago because it was looking a bit tatty. Went to B&Q brought some fine Wet 'n' Dry, Plasti-kote primer, laquer and Gold aerosol paint. Didn't take long to do and now it looks great. Could be an alternative for you?
Old 30-09-07, 08:00 PM   #5
Was the metal ring able to come off?
Old 30-09-07, 08:02 PM   #6
SAMMY650
Honestly, I didn't try to seperate the parts. Just used careful application of masking tape while painting different parts.
Old 30-09-07, 08:24 PM   #7
Brian
Darren, yes, read my post and link....
Old 30-09-07, 08:30 PM   #8
Sorry but I couldn't see any definite answers in either. But thanks
Old 30-09-07, 08:38 PM   #9
TSM
The Sick Man
TSM's Avatar
well, if it was put together then it must be able to come apart.
Old 30-09-07, 11:07 PM   #10
I had a wee look at one a while back and it didn't look particularily dismantlable- not held together with screws, at least. But that's as far as I went. I managed to damage mine a little by, yes, using the wrong length screws, but fixing it's low on the list
Oh yeah- if you decide to paint it, make sure that whatever paint you use is petrol proof... A lot of common paints will bubble or melt if dripped on, which isn't ideal for a filler cap Hammerite can even go runny on exposure to fumes.
Just had a listing removed from ebay... Paul the 6th Idle Banter 25 21-11-08 11:40 PM
Removed Stu For Sale - SV's and SV related items 5 18-08-06 09:05 AM
removed tigersaw For Sale - SV's and SV related items 0 16-05-06 01:47 PM
Blueflame baffle removed......... Davies SV Talk, Tuning & Tweaking 1 27-03-06 01:46 PM
Ermax Hugger - K4S - REMOVED! Baldyman For Sale - SV's and SV related items 6 07-12-05 08:44 PM
