Old 01-10-07, 07:49 AM   #1
MrRoper
Default Something just went bang..I think!!
Hi guys and gals,
Quick question.. I was starting my bike this morning, and as it turned over a plume of what looked like smoke came out from the tank. Could this have been the R/R blowing, is it situated under the tank!?!
if not what else is under the tank that might reat me when i lift it!
Many thanks
Old 01-10-07, 08:12 AM   #2
John Burt
Default Re: Something just went bang..I think!!
Probably just a litttle cough back through the carbs, the rect rect lives under the tail, bolte dto the subframe.
Old 01-10-07, 08:19 AM   #3
MrRoper
Ahh, ok..it definitely smelt electrical though Is there anything under there that could blow?
Old 01-10-07, 08:40 AM   #4
Spanner Man
Good morning.
There's quite a bit of wiring that lives under the tank, you had better lift the tank & see if there's anything 'black & orrible' under there just in case.
Cheers.
Spanner Man
Old 01-10-07, 08:44 AM   #5
MrRoper
Thanks for that, I will get the tank up when i get home, Is there anything else under there i need to be worried about?
Thanks
Old 01-10-07, 09:53 AM   #6
John Burt
Try checking all your fuses and the starter relay/main fuse - although these are under the seat they could look like the smoke cam from around the tank I spose. Like spanner man says there is a fair old amount of electrcial string under the tank though - best to have a butchers.
Old 01-10-07, 10:03 AM   #7
MrRoper
Thanks guys,
I will take a look under the tank at dinner time, the seat will have to wait to come off until tonight!!
Thanks guys
Old 01-10-07, 10:16 AM   #8
This may be just me being very silly, but on mine you have to take the seat off to get the tank off...
Old 01-10-07, 10:23 AM   #9
MrRoper
I was planning on just raising it on the hinge.. Will i still be able to see the wiring, or does it need to come off?
Old 01-10-07, 10:33 AM   #10
Most of the wiring is under the front of it and mainly runs down the LHS frame so you shound't need to get the tank all the way off
chitty chitty fecking bang bang hovis Idle Banter 35 03-01-09 12:33 PM
Bang! jumjum_0214 Bikes - Talk & Issues 25 23-07-08 08:19 PM
Bang! kwak zzr Idle Banter 9 05-11-07 11:03 PM
bang!!!! sv650nutter149 SV Talk, Tuning & Tweaking 18 15-08-07 07:14 PM
kill bill soundtrack bang bang hovis Idle Banter 8 22-05-07 03:53 PM
