Old 09-10-07, 12:08 PM   #1
Default computers
aaahhhhhhhhhh.
bl@@dy things! after trying to configure a net gear router for most of yesterday i finally gave up and reconnected my b band modem, now my pc wont boot? try a new power supply but still nothing? its dead?
i orderd a cheapo off ebay and that came this morning with bl@@dy linux on it? whats that all about? how do i get it off? now i'm really pi$$ed off posting from my dads house
Old 09-10-07, 01:03 PM   #2
Default Re: computers
stole my dads and just set it up at home
Old 09-10-07, 02:34 PM   #3
andyb
I'm confused, you ordered a power supply that came with Linux on it? How come your the only one to be getting post while the strike is on........come on mates in the know (Yes I know your a postie)
Old 09-10-07, 04:07 PM   #4
SoulKiss
SoulKiss's Avatar
aaahhhhhhhhhh.
DG864 Router Kwak?
As for getting Linux off it - well you need a copy of Windows with a valid CD Key to get started on that
Thems easy, let me know when you want to try again and I'll see if I can help you.
Old 09-10-07, 04:52 PM   #5
DG834G? its not auto detecting my settings? and the install keeps failing?
Old 09-10-07, 05:02 PM   #6
SoulKiss
SoulKiss's Avatar
All you should need to do is put in your ADSL username and password (at least to get ADSL working)
ADSL Settings
Multiplexing Method LLC-BASED VC-BASED VPI VCI That should be common to all UK ISP's
Encapsulation PPPoE (PPP over Ethernet) PPPoA (PPP over ATM) Login
Password
Idle Timeout (In Minutes)
Old 09-10-07, 05:04 PM   #7
yea did that but it wanted my ip address ect and it couldnt auto detect them its self.
Old 09-10-07, 05:07 PM   #8
SoulKiss
SoulKiss's Avatar
WAN or LAN address
WAN is the address on your ISP's network - should be auto assigned.
LAN can only be set automatically if you have a DHCP server on your network, which I assume you dont have.
Switch DHCP on in the router config
Old 09-10-07, 05:12 PM   #9
soulkiss i need you here i'm a complete dill when it comes to doing anything like this.
Old 09-10-07, 05:13 PM   #10
SoulKiss
SoulKiss's Avatar
Correction.
You need to give it an address in the 10.0.0.0 or 192.168.0.0 subnets
My config
LAN IP Setup
LAN TCP/IP Setup
IP Address 192.168.0.1 IP Subnet Mask 255.255.255.0 RIP Direction BOTH RIP Version RIP-2M Use Router as DHCP Server Starting IP Address 192.168.0.128 Ending IP Address 192.168.0.250 You then need to set up wifi so that only know equipment will get an address tho
Computers WTF! metalmonkey Idle Banter 17 21-11-08 08:56 AM
computers! Help! Alpinestarhero Idle Banter 3 09-05-07 07:57 PM
Anyone here know anything about computers? Diego's dealer Idle Banter 20 30-09-06 06:15 PM
Crystal Computers Grinch Idle Banter 1 11-05-06 11:43 AM
Before Computers sharriso74 Idle Banter 1 10-04-06 10:56 AM
