Old 11-10-07, 10:05 PM   #1
I'm_a_Newbie
Default Can the ECU be Remapped?
Hi All.
I was sure I read that the SV ECU can be remapped so you don't have to buy a Power Commander. I phoned Double Take Dyno in Southampton yesterday. They said they had never heard of it and that I needed a Power Commander.
It's a K3 model. Any ideas on this people?
Thanks
Tim.
Old 12-10-07, 07:48 AM   #2
Steve_God
Default Re: Can the ECU be Remapped?
Double Take Dyno are lying (or uninformed...) as you don't need a Power Commander.
At many Dyno centres, they can offer you a 'Yoshi ECU Editing' thingy... not 100% of the name now, but basically it's about £60-80ish, they put it on a Dyno, plug your ECU into a computer, and they can alter the fueling where needed by up to 5% either way from standard.
This is ideal for anyone who's put a free-flowing exhaust on and wants to get the fueling sorted out as cheaply as possible. I guess this is what you want it for?
Edit: I think it's called a 'Yoshi Box'!
Old 12-10-07, 07:51 AM   #3
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
steve jordan motorcycles can do it...
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 12-10-07, 08:40 AM   #4
SV650Racer
What ^^ says.
Double Take possibly just are not aware of it.
There are three systems.
Yoshi and Teka boxes can be used although they have a very limited range of adjustment. Costs for this are about £60-£80.
We use a system that can remap the stock ECU with multi positions and throttle openings creating a far better map. Plus because your utilising the bikes own software it works alot better than using an aftermarket box such as the Power Commander. Plus it works out cheaper as you dont have to buy the PC. Costs about £120.
Its only available for Suzuki's at the moment though.
Old 12-10-07, 04:16 PM   #5
Just out of curiosity, what system is that?
Old 12-10-07, 09:07 PM   #6
I'm_a_Newbie
Thank's for all the info.
I found a place in London using Google that said they can remap the standard ECU.
Steve Jordan sound promising. A bit far to though as I am near Portsmouth. I'd enjoy the ride though.
I need to check the valve timing, throttle balance and TPS adjustment before doing anything else. In case I got anything wrong after taking the front head off.
Tim.
Old 12-10-07, 11:10 PM   #7
Gynx
What kinda system does the Stock ECU navigate on ?
Speed Density based , ie MAP sensor or MAF sensor type... or eve something completely different ?
Old 13-10-07, 10:50 AM   #8
Not that I'm an expert on the pointy, but I believe its a pressure sensor in the airbox
Old 13-10-07, 02:05 PM   #9
mattSV
mattSV's Avatar
Tim.
Tim - Steve Jordan's could check all that for you at the same time The ride up there is no problem, you can either blat up the A3 or take the twisties, when I went up there I borrowed a courtesy bike and nipped up to Boxhill for a burger
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 13-10-07, 04:45 PM   #10
Gynx
if the sensor is in the Airbox , it would sound like a MAF sensor type setup (since pre-butterfly is always Atmospheric unless uve got a turbo with a blow through system , and a MAP sensor type requires the sensor after the butterfly to detect Vacuum as well as Atmospheric or positive).
Luckily , there not to hard to trick into changing... Im guessing thats how these ecu fuel modifiers work... piggy back style.
remapped ?????????????? jans1971 Bikes - Talk & Issues 0 04-09-07 06:56 PM
