Old 14-10-07, 11:07 PM   #1
Default Chain wear
This is a good one for you mile munchers.
The chain on the bike (came with it when I bought it) is a DID, with I beleive OEM sprockets.
This one has been abused plenty by me, and is starting to show. Before I put the scottoiler on I was lubing it once every 2 days (100 miles ish) and having to adjust it every week. Since the scottoilers been on it hasn't lost its proper tension yet.
There is about 1/2" of sideways play in it.
Is it FUBAR? How long will it survive?
(scottoiler is a universal one, and it runs a full fill in about 400 miles)
Chris
Old 15-10-07, 06:39 AM   #2
Flamin_Squirrel
Default Re: Chain wear
How many miles has it done, and what does losing its proper tension mean?
Old 15-10-07, 02:09 PM   #3
No idea how many miles, at least 5k with me
Losing its proper tension = going really slack and needing adjusting
Old 16-10-07, 07:01 AM   #4
Spanner Man
Morning old boy!
When you say 1/2 an inch of sideways play, whereabouts are you measuring it?
Cheers.
Spanner Man
Old 16-10-07, 09:24 AM   #5
ridelikeaturtle
It would sound like something's not right w/the amt of readjusting you were doing, as every 100-ish miles is WAY too frequent. Checking the tension every 600-ish miles would seem more normal, and that doesn't necessarily mean readjusting it (if it's been lubed properly it may not need adjustment.)
I just put a Scottoiler on my SV and so far I haven't needed to do any adjustment; though I didn't have to do any adjustment before since I kept it properly lubed anyway.
I've had a motrax 'lubetronic' on my ZX9R and haven't had to readjust the chain for nearly 4000kms. (Aside: the 'lubetronic' is roughly the same cost, is electronically operated (not vacuum), and seems to have a much longer range than the Scottoiler. So far I prefer it to the Scottoiler, as its easier to maintain and install.)
If your new Scottoiler seems to be doing the job, just keep an eye on things and you're probably fine.
Sorry I don't seem to be a whole lot of help...
Old 16-10-07, 09:37 AM   #6
Baph
I've never had to adjust a chain in the last 30,000 miles. (and yes, I check it frequently).
What's my secret? 2000 miles a month on the bike, constantly lubing the chain (properly - as in stripping the old stuff off with parafin & re-applying every couple of days). The distance means I'm frequently getting new rubber fitted, and they've always checked the chain tension then (and adjusted if needed).
But seriously, if 1/2 inch sideways movement is in the middle of the two sprokets (perticularly on the bottom rather than the top), I wouldn't worry about it.
Try pulling the chain backwards off the rear sproket & see how much of the tooth is revealed, and try moving the chain sideways at the top of the rear sprocket.
Old 16-10-07, 09:40 AM   #7
Alpinestarhero
What do the teeth look like? Are they "hooked"? This would indicate time for renewal. I lube my chain every week with wurth chain lube (although I dont really like it, it seems too dry and I'm sure thats not good) after cleaning all the crap off. I've only had to adjust it once in about 3000 miles, and that was when I had new tyres fitted (much like baph, then)
Im sure the chain will be ok, but keep an eye on it and note any particular tight spots
Matt
Old 16-10-07, 10:00 AM   #8
Originally Posted by Spanner Man View Post
Morning old boy!
Cheers.
the bottom run in between the sprockets.
It hasn't needed adjusting in the last 800 miles ish so not too bothered by it if that amount of play is normal, theres no tight spots in it so will leave it be.
The chain seems pretty wet with oil but theres very little fling on the back wheel, I'm guessing this means I've got the flwo about right?
Old 17-10-07, 06:48 AM   #9
Spanner Man
Morning old Horse.
The best way of determining how much wear a chain has, is to hold the chain tight by pushing the bottom run upwards with your left hand, & try to pull the chain off the sprocket at the 3 o'clock position with your right hand. Any movement suggests that the chain is starting to wear, if as Baph says you can expose the bottom of the teeth it's definitely on it's way out.
Cheers.
Spanner Man
Old 14-11-07, 09:55 AM   #10
dyzio
dyzio's Avatar
Don't want to start a new thread so I'll post it here.
I gave my chain a clean with B&Q's white spirit (paraffin based) and I've also bought this now.
Effect? Chain is CLEAN, however, it needs frequent adjustment now (every 300-500 miles).
Is that because the stuff I used is cr*p, and has damaged the chain,
or the chain is on it's way out (17k), I think it's the original one (DID, bike bought on 10k).
One other thing, this stuff is also great for cleaning rims Just hope the paraffin won't damage the tires... (?)
cheers
Uneven chain wear rockster SV Talk, Tuning & Tweaking 17 16-05-09 08:03 PM
what do you wear? Wideboy Idle Banter 26 17-05-08 11:11 PM
What makes a chain wear due to lack of oil? muffles Bikes - Talk & Issues 16 09-06-07 09:14 AM
Mixing chain wear tomjones2 SV Talk, Tuning & Tweaking 1 29-04-07 02:26 AM
To wear, or not to wear.. rubberduckofdeath Idle Banter 25 28-03-06 01:15 PM
