Old 15-10-07, 08:51 AM   #1
thor
Default Counter counter steering - does it exist?
Hi, sometimes I've managed to brake hard in a corner, and had to steer the opposite way to normal, ie counter counter steer. The front wheel has always felt on the limit of grip and i've been fighting to keep the bike lent over. Total bollox?
Old 15-10-07, 09:01 AM   #2
Idleater
Default Re: Counter counter steering - does it exist?
If you are on the front brake while turning, the bike will be trying to stand up. Then if you release the brake the front will drop over again.
could this explain it?
Old 15-10-07, 09:05 AM   #3
plowsie
Use the rear in a corner and you can tend to keep it at same lean, dont hit it too hard though as you will be goin further and further and further and doh!
Only use this if im hot in a corner mind.
Old 15-10-07, 09:15 AM   #4
Viney
DONT DO IT!!! You'' upset the space time continum and go back to 1955!
Cranking on the front barke in mid corner is baaaad. As siad the bike will sit up and want to go straight. Unless youre very heavy and can still lean the bike round!
Old 15-10-07, 09:17 AM   #5
thor
That's what I am saying, I am pushing on the bars the other way, ie, push right bar forward to go left, to keep the bike cranked over.
Doesn't happen often mind....
Old 15-10-07, 09:25 AM   #6
Baph
Push right bar forward to go left...
That's counter steering. Not "counter-counter steering."
Old 15-10-07, 09:27 AM   #7
Grinch
Yes I do it all the time, I lean on rights, and counter steer on lefts.
Old 15-10-07, 09:48 AM   #8
muffles
Wouldn't counter steering be pushing on the left bar (turning it to the right) to go left? It's quite confusing the way it's said though!
Old 15-10-07, 09:52 AM   #9
Baph
Nah, counter-steering is pulling on the right bar to go left.
(I stand corrected )
Old 15-10-07, 09:55 AM   #10
plowsie
Can you imagine an onlooker trying to picture and run the motions through their head, i'm doin knots in my small brain!
Why Don't They Teach Active Counter Steering? I'm_a_Newbie Bikes - Talk & Issues 89 04-03-09 07:48 AM
Counter steering? neillfergie Bikes - Talk & Issues 14 28-05-08 11:28 AM
Rev counter! Slim666 SV Talk, Tuning & Tweaking 9 26-06-07 01:36 PM
Rev counter Slim666 Stuff Wanted 0 25-06-07 10:15 AM
What is counter steering hall13uk Bikes - Talk & Issues 11 25-05-05 09:47 AM
