Old 21-10-07, 03:19 PM   #1
stewie
Default Seat padding
Ive just sculpted me seat down by approx 35 mm and can now just about get the balls of me feet down but could go another 25 mm I reckon, the problem is it leaves not a lot padding under the seat so was going to put a gel pad under the cover until I saw the price. Then I had a brain wave, has anyone used the closed cell foam padding that campers use under there sleeping bags ? you know the roll mats that we had at the AR last year and if so are they any good ?
Ta
Ooops, thanks Paws
Last edited by stewie; 21-10-07 at 03:52 PM. Reason: Missed a vital word out !!!!!!!!
Old 21-10-07, 03:49 PM   #2
Paws
Default Re: Seat padding
Originally Posted by stewie View Post
Ive just sculpted me seat down by approx 35 mm and can now just about get the balls of me down Ta
anyone else spot the mistake in this post???
Stewie-re-read that bit.....
Old 21-10-07, 03:56 PM   #3
stewie
What a plonker I am
Old 21-10-07, 03:58 PM   #4
Lissa
Just Ballast
Lissa's Avatar
What a plonker I am
I think 'kn*b' is a more appropriate word
Old 21-10-07, 09:18 PM   #5
embee
embee's Avatar
..... has anyone used the closed cell foam padding that campers use under there sleeping bags ? ......
Yes indeedy, it's good stuff to use sparingly. It can be a little firm but does absorb impact extremely well.
Don't scrimp though, the really cheap stuff is pretty rubbishy, pay a little more and get the twin layer ones, last one I got was about £6 IIRC, two different foams in light/dark grey.
If you do want gel pads, I found the cheapest way was from horse tack suppliers, they do big ones for under saddles (sometimes go under the name "numnah"). The one I bought was proper gel inside a tough nylon type cover, some seat modifiers actually use silicone rubber honeycomb but describe it as "gel-pads".
I found the best stuff to seal the edge of the gel pad when cut to size was the pvc tape used to join ventilation ducting (doesn't come unstuck with time). The gel pads are very heavy though.
Old 21-10-07, 11:25 PM   #6
stewie
Cheers Murray, gonna use some of the foam padding to start with and see how I get on with it, ive got a bed roll from last years AR with the dual layers so will give that a go
Ta
Is 650 seat the same fitting as the 1000 seat ? genesismike SV Talk, Tuning & Tweaking 8 05-05-09 06:11 PM
Gel Seat & Yellow Seat Cowl - just put them on ebay mike_avfc For Sale - SV's and SV related items 8 06-10-08 06:19 PM
My bike and other bits for sale-end can,seat cowl,rear seat and others monkey For Sale - SV's and SV related items 1 10-08-07 12:26 PM
K6 - New riders seat, New full power ECU, Blue seat cowl & owners manual ivantate For Sale - SV's and SV related items 15 19-06-07 09:44 PM
pillion seat and a silver seat cowl for K3 lukemillar Stuff Wanted 2 08-02-06 06:01 PM
