Old 23-10-07, 03:53 PM   #1
Flamin_Squirrel
Default Race clip-ons
Following my off on sat I need a new clip-on. Seeing as they're not cheap from breakers, there are none on ebay and a new replacement is verging on extorsion, I'm thinking of getting some race clip-ons.
However, something that concerns me is what'll happen if I drop it again. As there is no lug/bolt to locate into the yoke, the only thing that'll stop the clip-on from rotating if hit hard enough are the pinch bolts.
Seeing as I cant see the pinch bolts putting up much resistance in a crash, am I likely to have the clip-on rotating on the fork and damaging the tank?
Old 23-10-07, 09:02 PM   #2
SoulKiss
SoulKiss's Avatar
Default Re: Race clip-ons
Which side do you need?
David
Old 23-10-07, 09:06 PM   #3
Flamin_Squirrel
Right. But unless the clip on you've stumbled on is from a K3-4 GSX-R1000, it wont fit
Old 23-10-07, 09:24 PM   #4
Razor
I had some helibars, only the pinch bolt secured them. In my crash last year the right one bent before moving. I still dented the tank, but that was with my knee slider...
Old 23-10-07, 10:09 PM   #5
The locating bolt is just that, so the 'bar goes in the right place, it adds sod all to the resistance of the clip on rotating, if there's enough force to move the clamp on the fork leg the locating bolt will give out in a heartbeat - so don't worry about it.
Old 23-10-07, 11:59 PM   #6
My LSLs only have the pinch bolts and didn't move an inch when I, er, tested them. But then, they're designed that way. I've always been a bit less sure of that with ones that come with location bolts or pins, but then, I'd listen to Mr Squid
LSL High-offset Sports Match by the way, are excellent for the SV/GSXR conversion- you lose clipon height 2 ways with GSXR parts, the forks are short and the bars are low. Most race clipons are lower still, the LSLs give you some height back. Which you may or may not want, but I was glad for it. Top tip from SV650Racer, those. Not cheap, though, but then, not drastically more than a used pair of OE ones.
Old 24-10-07, 06:31 AM   #7
SoulKiss
SoulKiss's Avatar
Your right - its a pointy SV one I have sitting spare
Old 24-10-07, 06:41 AM   #8
21QUEST
21QUEST's Avatar
Jordan, what side/year do you need......might have something for you
Ben
Nemo me impune lacessit.
Old 24-10-07, 06:42 AM   #9
21QUEST
21QUEST's Avatar
haha, note to self...........read the whole frigging thread properly
I'll PM you with some options after I've looked through tonight
Ben
Old 24-10-07, 07:44 AM   #10
Flamin_Squirrel
Cheers!
Crash.NET - Rossi: Great race in dry, no race in wet? NewsBot News 0 13-09-08 10:40 PM
Clip ons Taylor1975 SV Talk, Tuning & Tweaking 3 24-03-08 02:39 PM
Clip-ons....(from flat bars to clip-ons) Gnome SV Talk, Tuning & Tweaking 6 12-07-07 06:57 PM
clip on for a k3 rafcc SV Talk, Tuning & Tweaking 0 13-03-07 11:45 AM
Race Sponsorship - Race For A Season For 20 Quid Mike1234 SV Talk, Tuning & Tweaking 0 01-01-06 06:10 PM
