Old 26-10-07, 11:38 AM   #1
mattglavin
Default Carb Cleaning
Has anyone found the best product to either spray into the Carbs or add to the fuel to clean the fuel system ?
Old 26-10-07, 11:47 AM   #2
Default Re: Carb Cleaning
Wynns make a few carb cleaing products, I prefer the old fashioned way of draining some fresh fuel through the system, or if they're really bad then take the float bowls off and clean them the old fashioned way.
Old 26-10-07, 02:24 PM   #3
embee
embee's Avatar
Carb or injector cleaner additives do work, though they won't clear out crud like rust powder. They'll usually reduce deposits from evaporated fuel (varnish/gum).
Use a well known brand available at car accessory shops, something like Redex is a safe bet. Stick to the recommended dosage, more is not better.
You can use Injector cleaner in carbs with no probs. They are pretty much all catalyst/lambda sensor friendly since they are usually straightforward hydrocarbon products with no metallic elements added (which are the things which will usually do the damage).
Old 27-10-07, 01:36 AM   #4
That fact is why I prefer to clear the float bowls out manually.
As for lambda sensors and cats, not really valid for a curvy, and even a catted bike can be ignored as theres no emissions test on the MOT.
Old 29-10-07, 12:29 PM   #5
johnnyrod
johnnyrod's Avatar
Elbow grease
Cleaning, how far do you take it? TheStudent SV Talk, Tuning & Tweaking 11 06-03-09 11:39 AM
pipes going to carb to carb sv650nutter149 SV Talk, Tuning & Tweaking 3 07-09-08 10:16 PM
Solvent for cleaning and soaking carb bits please petevtwin650 SV Talk, Tuning & Tweaking 11 23-05-06 02:42 PM
Cleaning? fizzwheel Idle Banter 17 15-02-06 09:17 PM
Cleaning Kit markfc SV Talk, Tuning & Tweaking 13 17-02-05 04:21 PM
