Old 04-11-07, 03:04 PM   #1
seano
Default Weird engine kill.
I have a 2001 curvey which has developed a strange alternative to the kill switch, in that at low engine speeds such as are used when doing slow manouvers, when I turn the bars to initiate a left turn the engine cuts out. I noticed this afew times so checked to see if this happens all the time when the bikes stationary, sure enough it does. The engine is warm turn the handles right continues running, turn the handles left the engine cuts out. Has anyone experianced this or am I the first? I don't feel like fault finding this week so if you can help I would be most greatfull.
Old 04-11-07, 03:38 PM   #2
hovis
Default Re: Weird engine kill.
sounds like the kill switch wire....... maybe its damaged & shorting ? or it may need re-routing?
Old 04-11-07, 10:05 PM   #3
Sounds like it, or it could be the connector thats come loose
Old 08-11-07, 10:47 AM   #4
seano
Cheers, I'll get looking once I have time.
Old 08-11-07, 12:21 PM   #5
AlanB
Does the clutch lever have a cut out on a curvey, if so check those wires as well.
Old 08-11-07, 12:22 PM   #6
That only affects the starter circuit
Old 08-11-07, 01:08 PM   #7
Smudge
another point of view is if your throttle cables are too tight and when you turn you loose them
Old 08-11-07, 01:09 PM   #8
How would that kill the engine?
If they're too tight it will just rev a little at full lock
Old 08-11-07, 01:19 PM   #9
Smudge
i had mine too tight on my RD and set the tickover and when i turn full lock left it died
Old 08-11-07, 06:13 PM   #10
I'm still thinking electrical, but Smudge is right - if the 'A' throttle cable is a dab tight and the linkage is being held off the tickover stop, then the cable is now the tickover adjuster - turning the 'bars could slacken the cable enough to drop the tickover to an unsustainable level.
every one wants to kill me! captainsmelly Idle Banter 40 07-10-08 04:57 PM
I need to kill melody Idle Banter 18 04-09-07 04:39 PM
Key? Or Kill? MitchC Bikes - Talk & Issues 28 21-08-04 01:57 PM
Key? Or Kill? 21QUEST SV Talk, Tuning & Tweaking 25 02-01-70 02:04 PM
