Old 09-11-07, 10:22 PM   #1
SAMMY650
Default Cables And Belly Pan
Evening all!
I brought a sv650 bellypan (curvy) from Busters, they've sent me the numbered instructions but step 4) says to "install brackets on to engine using original engine bolts as shown on diagram" but there where no diagrams in the box. I tried contacting Busters but I'm STILL WAITING for them to reply and Powerbronze just send the numbered instructions with no diagrams again!! (its a powerbronze bellypan)
Does anyone have the diagrams or close up photos of one already fitted?!
Also, I fitted Renthal bars to the SV but the choke and throttle cables are too short as the revs go through the roof when bars are turned, does anyone know what cables I'll need? Either length or model of different bike that'll work?!
Please help
Old 09-11-07, 11:03 PM   #2
Default Re: Cables And Belly Pan
with the belly pan you can offer it up to the underneath of the bike and pretty much guess which brackets fit where, the very short straight bracket fits down by your right foot (back brake pedal) the long straight bracket the other side by your gear change, the one shaped similar to an "s" fits gear change side but to the front of the engine and the last bracket to the other side, hope this makes some sort of sense to you.
daz.
Old 09-11-07, 11:11 PM   #3
hope this helps, i know its a pointy but same engine really
Camcorder cables jaffacakes Idle Banter 2 02-12-08 07:12 PM
Clutch cables/Throttle cables Curvy 21QUEST For Sale - SV's and SV related items 0 05-08-08 08:45 AM
Someone cut my throttle cables! SVeeedy Gonzales Bikes - Talk & Issues 42 29-03-07 12:16 PM
Bar Risers and cables drumwrecker SV Talk, Tuning & Tweaking 2 21-03-06 08:34 PM
oiling cables? kwak zzr SV Talk, Tuning & Tweaking 6 19-03-06 03:23 PM
