Re: SV650s Fairing fitting Kit
@phil they sell the four (or five) plastic clips that join the lower fairing together on ebay
@imnosuperman nobbylad is right the problem with the cheap crash bungs is that if you have an off the bike weight will easily break the standard fairing clips that are replaced when you buy r&g crash bungs with fittings that are a million times stronger |
The clips, yes. The plastic bracket, no. Wouldn't want to make a metal one of these due to flex etc but I'm sure something could be fashioned with a dremel, drill and some suitable plastic!
the plastic bracket was attached (plastic welded) to one half of my fairing
