-   Bikes - Talk & Issues (http://forums.sv650.org/forumdisplay.php?f=129)
-   -   Debrix emu and spring change (http://forums.sv650.org/showthread.php?t=207947)
muzikill 03-03-14 08:24 PM
Re: Debrix emu and spring change
The damper rods sussed its the fitting of the emulators. Im sure I read the oem spacers were unusable with this mod.
Sent from my GT-I9505 using Tapatalk
chris SVK3 03-03-14 08:41 PM
You can trim them down by the length of the emulator but it depends on the the sag you get when your on the bike. You have to bear in mind if you take the preload adjuster out to the max is about the same as the height of the emulator approx 15mm
muzikill 03-03-14 08:50 PM
15st of sag!
chris SVK3 03-03-14 08:53 PM
What spring you got. If 8.5 I would leave spacer alone until you measure the rider sag
muzikill 03-03-14 09:50 PM
Not bought a new k tech one yet. Still oem inside the fork.
chris SVK3 03-03-14 09:54 PM
Do not cut the spacer then and it would really be worth getting new springs
muzikill 03-03-14 10:27 PM
Yup k tech on the cards. I need to do some research to work out which ones.
chris SVK3 03-03-14 11:03 PM
Give them a bell. They are really helpful. Told them my requirement 12st rider with emulators mAinly track days with a bit of road riding and they said I was inbetween the 8.5 and 9 but recommend the 8.5 if I preferred a plusher ride.
muzikill 04-03-14 12:17 PM
Cheers chris. I appreciate the advice.
embee 05-03-14 11:17 PM
Same, 12st and the 0.85's are spot on for me (road riding).
