Old 06-03-07, 04:20 PM   #1
svryanpompy
Question R6 throttle tube
im always looking for ways to make my 2oo1 sv better
i notice people talking about the R6 throttle tube
i wont to know what year of r6 do u use and is it easy to change round?
but most of all i wont to know what it dose for the sv?
dose it improve the throttle response?
thanks for your help
Old 06-03-07, 04:24 PM   #2
fizzwheel
fizzwheel's Avatar
Default Re: R6 throttle tube
use the search function, you'll find 4 or 5 threads covering this..
Oh and this is the part number you want, which I pinched from a previous thread on this subject
Originally Posted by BILLY View Post
Here's the part no. for you 5SL-26240-00-00
Old 06-03-07, 04:38 PM   #3
svryanpompy
ok thanks for that had a look tho the pages
might give it a try
Old 06-03-07, 04:45 PM   #4
Blue_SV650S
Its a simple enough job. The idea is to reduce the throttle turn from 1/4turn to 1/5 turn. This basically means you can get to full throttle without as big a 'twist'. It won't imporve bike perforance, but does increase rider/wrist comfort!!
Old 07-03-07, 12:57 PM   #5
redlavachips
why dont you just tighten the throttle cable???
Old 07-03-07, 01:16 PM   #6
fizzwheel
fizzwheel's Avatar
Because you need a certain small amount of free play in the throttle. If you tighten the throttle cable to much you'll end up with an extremely sensitive throttle and your bike will be a bitch to ride.
Old 07-03-07, 01:53 PM   #7
(oooo resists an e.d comment.. )
I said nuffin I said nuffin- wssssssnt me .!
I have done this.. costs £8 and ten minutes.. and the grip aint too far of a match either..
certainly doeant make the bike go quicker or dont expect miracles but saves u having to "break" your wrist and re adjust ..
Old 07-03-07, 11:11 PM   #8
PeterM
Because that does not affect the amount of cable the throttle pulls through a turn simply.
Think about the gears on a push bike leaving the gear at the wheel in the same spot if you change from the small cog at the crank to a larger one you go further for a given revolution of the crank. Exactly the same principle.
Old 08-03-07, 09:17 PM   #9
SVeeedy Gonzales
I tightened the throttle cables as well as doing the R6 tube. It's not much fun to ride - every bump/slight hand movement has the bike accelerating or decelerating and you can mistake the front forks for a pogo stick. It's worst in low gears, though you can still get by slipping the clutch.
I settled for about 1mm of freeplay and slip the clutch when I need to. It's easy enough to play about with the cable play at the handlebar end.
R6 Throttle tube mod done Lozzo SV Talk, Tuning & Tweaking 7 06-02-13 03:28 PM
R6 Throttle Tube plowsie SV Talk, Tuning & Tweaking 0 19-06-07 10:21 AM
R6 Throttle Tube jonboy SV Talk, Tuning & Tweaking 128 06-01-07 06:41 PM
throttle tube 01 sv650s SV Talk, Tuning & Tweaking 1 21-11-06 02:25 PM
R6 throttle tube for a K4 SVeeedy Gonzales SV Talk, Tuning & Tweaking 0 04-01-06 12:22 PM
