Old 27-10-07, 01:41 AM   #21
Default Re: Both right side indicators not working ;(
Originally Posted by drefraser View Post
when I get back. I've got my manual complete with wiring diagram; I just need to find a .jpg of an oily thumb print to paste on to it.
The solution may be in sight ...
Not really the same working from a clean wiring diagram You can always tell the hard jobs on a bike when the pages of the manual have blood splats...
Old 05-11-07, 09:56 PM   #22
drefraser
Smile Victory !!!
I came back after my soaking weekend walking in the hills and checked the area under the seat where the tie down strap could have rubbed. Unfortunately there were no wires that could have been damaged in that area. So that was it then. Demonic possession seemed to be the obvious and only explanation.
So do you want to know the Agatha Christie mystery answer? It was a broken wire in the loom. Where I don't know because I've rewired the whole lot. But when I checked the rear right bulb initially I put the bayonets back 180 degrees from where they had been. What I hadn't twigged was that someone had replaced a 21w bulb with a 23w/6w rear light /brake light bulb. So when it went in in a different way to the way it came out it changed from a 23 watt to a 6 watt output. Because there was no power getting to the indicators at that point I didn't spot any difference. It was only when the electricity started flowing again that the weird double speed flashing happened.
Obvious really.
Old 05-11-07, 09:58 PM   #23
Default Re: Victory !!!
That was the solution I went for too
New indicators fitted - not working right. wilky007 SV Talk, Tuning & Tweaking 8 21-02-09 04:31 AM
Speedo working, then not, then working??? krhall SV Talk, Tuning & Tweaking 25 24-04-08 11:35 AM
making side lights into indicators. younggunns SV Talk, Tuning & Tweaking 29 14-04-08 09:42 PM
Remove front indicators space -Move indicators in headlights JanGoris SV Talk, Tuning & Tweaking 5 19-04-06 09:27 PM
side lights to indicators unlucky rider SV Talk, Tuning & Tweaking 6 26-02-05 04:25 PM
