Some help would be appreciated.
I've got a 1999 naked SV650. Intermittently initially, and now constantly, the right front and rear indicators have stopped working. The left indicators are fine. I've checked the bulbs and the earth connections front and back and they're fine. One more bit of info is that the green indicator light on the dash comes on but at a faster rate the same way it does if you blow one bulb. I thought it might be the flasher relay unit but then I thought that the dash light wouldn't work if that was the problem. I also don't know where the flasher unit lives or what it looks like. Any ideas greatly appreciated. Cheers, Ewan |
Broken wire in the loom, maybe where the wire splits to the clocks and to the main part of the loom. Its a green wire IIRC
You have a bad connection somewhere in there, what you need to do is find it. I've always found it easier to work one one for a start and wiggle the wiring back as far as possible from the indicator. What you're trying to do is to make and break the wire so a gentle wiggle is best don't yank it or you can end up worse than you were. Pay particular attention to any points where rubbing can occur as the wires can chafe through. The way that you describe the indicator light suggests that its a fault in the wiring to me rather than the relay so unfortunatly it looks like a bit of work will be needed. Try the connectors as well, taking them apart and pushing them back together, rub them with a cloth to dry and clean them before doing so.
sorry can't be more help. cheers Alan |
The route I would go is pick up the wire as it comes out of the switch, and snaplok connect a fresh bit of wire right into it, then clip it in to the indi wire right at the back, see if that gets power to the front one as well.
Bodge city, but quick.
I have a similar problem at the mo which I'm trying to work through. Both left indicators have a habit of giving up the ghost until I have a fiddle with the relay. The right side works fine, which after consulting the wiring diagram led me to believe it might be the handlebar switch. I took it apart and cleaned it but it made no difference. It might be worth trying for you though as your fault is a little different. My dash light works correctly with the indicators and at the correct speed. I can fix the fault by wiggling the relay and fuse box which is under the seat over the battery. So this evening I'm going to try and take out every connector, clean it and put it back.
#6 | |
I wish.
Hateful things with intermittent faults and breaking down with heat and such ![]() That must be the appeal of 2 strokes, only 3 wires to possibly go wrong and when it siezes up its obvious whats gone wrong!
Ha Ha ......yeah I know what you mean.
Its infuriating when you think you have fixed it and then half way through your journey the fault returns. The other day I thought I had fixed them, went to do a left, indicated, they didn't work, did the left without realising and some car pulled out of a side street in front of me. Not really his fault as he didn't know I was turning, and I was going slow, so no drama, but its just really, really, annoying when something so important has an intermittant fault!!! Going to try to fix them again this afternoon as it was too wet yesterday. |
#9 |
Right. Another 2 1/2 hours I'll never get back.
I checked the flasher relay but jiggling it made no difference. Thinking about it (now that I've fiddled) there is only one intermittent live that goes from this unit forward to the handle bar switch where it then splits either right or left. So the fault must be in the switch or the wiring that comes out of the switch before it splits to go to front and back indicators. With some trepidation I took apart the left handlebar switch cluster and right enough there was a ping as vital bits of brass plate, springs and/or screws launched themselves into the dark recesses of the garage. There was no resistance between the output wire of the left indicator switch and the live of the front left indicator whereas there was infinite resistance between the right indicator switch output and the live of the right indicator. I traced the pale green output wire for the right indicators to a connector box in front of the tank after which it disappears into the main loom. At this point it was still continuous with the handlebar switch according to my multimeter. I looked for it in a couple of places in the loom by cutting the insulation open and also by the battery and in the tail where the rear indicator live must be. All without success. Being narked off by this point I thought I'd try a bodge as Yorkie suggested. I've connected the output from the indicator switch directly to the live of the front right indicator in the front headlight housing. The live is still also connected to the loom. This sort of works in that both right hand indicators now flash but at double frequency. Having read about problems with LED indicators while seeing if anyone had had this trouble before it seems that if you put a resistor in line with the live wire the flash frequency will go down. A sort of bodge on a bodge. Thanks for your suggestions thus far. I think anyone who has read this far will either have exactly the same problem or severe insomnia. I'm off to do something easier. Brain surgery maybe. Cheers, Ewan PS I really should get a manual. |
#10 | |
And really really stupid question, but when you are checking the switch for continuity, are you sure you have got it switched to left or right (done that one myself)
Now rebuilding a 63' fishing trawler as a dive boat Last edited by yorkie_chris; 17-10-07 at 11:46 PM. |
New indicators fitted - not working right. | wilky007 | SV Talk, Tuning & Tweaking | 8 | 21-02-09 04:31 AM |
Speedo working, then not, then working??? | krhall | SV Talk, Tuning & Tweaking | 25 | 24-04-08 11:35 AM |
making side lights into indicators. | younggunns | SV Talk, Tuning & Tweaking | 29 | 14-04-08 09:42 PM |
Remove front indicators space -Move indicators in headlights | JanGoris | SV Talk, Tuning & Tweaking | 5 | 19-04-06 09:27 PM |
side lights to indicators | unlucky rider | SV Talk, Tuning & Tweaking | 6 | 26-02-05 04:25 PM |
